Front Turn and Hazard/Flasher - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 7th, 08, 04:18 PM Thread Starter
67RS
I have a 67 RS.. I am building from the ground up, and want to confirm a couple things. I recently used the AAW classic update kit and everything worked great - really good product and support.. However, I started thinking.. I have turn signals working in the back correctly, but should the front park lights also blink to signal turns? Is there anything from the front of the car that signals a turn? And, I don't see a hazard switch anywhere.. Was the concept of a "hazard or flasher" switch on 67's?.. I have gone through the AIM but can't get a clear picture on how things should work...
deere2210 is offline
post #2 of 3 (permalink) Old Dec 8th, 08, 06:37 AM
Re: Front Turn and Hazard/Flasher
The front park lights in the valance panel are turn signals also, double wired socket, one for parking - brown, the other color for turn.
Make sure socket/reflector has a good ground.
post #3 of 3 (permalink) Old Dec 8th, 08, 07:24 AM
There should be a chrome knob on the steering column you push in to activate the 4-way flashers; the switch is part of the turn signal switch assembly.
Do you have both flashers installed on the fuse box? The Update fuse box has one circular area where it is clear that a flasher mounts, on the lower right corner. The second flasher mounts in the upper left hand corner of the box.
Eric
Eric Kammerer is offline
