Cowl induction wiring - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 7th, 08, 05:31 PM Thread Starter
I have a 67 camaro . I'm installing a cowl induction system . Does anyone know why there is two wire connections to the fuse panel . I know my panel does'nt have the connections .the system i have is for a 69 where there is a port for both wire hook ups . Can i hook both to a ignition port . Also is the switch on the throttle arm is it a wide open throttle or a variable switch. Thanks Joe
joe azzaretto is offline
post #2 of 7 (permalink) Old Dec 7th, 08, 05:35 PM
ALAN
RATHOWSE's Avatar
Re: Cowl induction wiring
not sure about the fuse box hook up on the 67 but the switch is full open, i am currently putting this in my 69
RATHOWSE is offline
post #3 of 7 (permalink) Old Dec 7th, 08, 07:48 PM Thread Starter
Thanks Alan for your reply . Do you have an idea for the location of the relay under the hood. Thanks Joe
post #4 of 7 (permalink) Old Dec 8th, 08, 08:47 PM
ALAN
RATHOWSE's Avatar
I actually read about 10000 posts last night under the wiring section, PM me and I will send you some pics I found, basically it is to the left side of the wiring gutter a couple of inches below it. the 69 ***. manual will give you the exact dimensions for that and the firewall penetration for the harness. but I am picture guy
RATHOWSE is offline
post #5 of 7 (permalink) Old Dec 9th, 08, 10:38 PM
Hey Guys, If it helps I could take a digital picture of the relay on my original 69Z and email it to you, just let me know.
I think it is approx just below the wiring gutter near the end passenger side , but not to the left.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #6 of 7 (permalink) Old Dec 10th, 08, 04:39 AM
Pics in this thread: https://www.camaros.net/forums/showth...ght=cowl+relay
Wiring is discussed here: https://www.camaros.net/forums/showth...ght=cowl+relay
More discussion: https://www.camaros.net/forums/showth...ght=cowl+relay
More pics from the "what it is, where it is" sticky in the Electrical forum. https://www.camaros.net/techref/elect.../cowl_hood.htm
Eric
Eric Kammerer is offline
post #7 of 7 (permalink) Old Dec 10th, 08, 08:02 AM
ALAN
RATHOWSE's Avatar
Thx Eric, those were the exact pics I found. I did not look there first however. but it sure was fun looking at all the posts. Thx Al
RATHOWSE is offline
