My amp/volt cauge is acting like a tachometer, help! - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 12th, 08, 08:57 PM Thread Starter
Question My amp/volt cauge is acting like a tachometer, help!
Like the title says, my console gauge is acting like a tach. At idle it is straight up "0". As I increase rpm the gauge goes positive and will peg the gauge to the right. back down to idle the gauge comes back to straight up "O". I drove the car at a steady 60 mph for about 12 miles. The gauge did not drop off the pegged position. I thought it would if it was truly charging the battery.
I recently had the battery go down over night due to a stuck relay on my power antenna. Down to 3.32 volts. After charging the battery back up to 10.5 volt I got the engine started. This is when the volt/amp gauge started acting goofy.
Could it be the regulator? It is a replacement transistor version of the original point type. Maybe it's fried?
Need help,
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #2 of 7 (permalink) Old Dec 12th, 08, 09:06 PM
Re: My amp/volt cauge is acting like a tachometer, help!
After a severe discharge, a battery charging will show these symptoms. Leave an external charger on it and amp readings should not be so severe during normal driving.
Regulator is doing its job.
post #3 of 7 (permalink) Old Dec 13th, 08, 07:15 AM
prostreet69camaro's Avatar
You could have hurt the battery being discharged so low. How old is the battery?
prostreet69camaro is offline
post #4 of 7 (permalink) Old Dec 13th, 08, 09:43 AM Thread Starter
The battery is about 1 year old. It's a red top Optima.
__________
post #5 of 7 (permalink) Old Dec 13th, 08, 10:31 AM
Does your car have a shunt or does it use the charging cable to the battery as an ammeter shunt? You might have a bad connection in the shunt circuit that is developing too much voltage for the meter circuit.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #6 of 7 (permalink) Old Dec 13th, 08, 01:47 PM Thread Starter
I charged the battery last night till the charger send "full charge". I took the car for a drive this morning. All seems good at this point.
Thanks for the input,
__________
post #7 of 7 (permalink) Old Dec 13th, 08, 09:47 PM
Cool!!
