Headlights - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 15th, 08, 09:16 PM Thread Starter
Headlights
I'd like to know the correct procedure for adjusting the headlights on a 69 camaro...thanks
Black 69 camaro
HOTROD69CAMARO is offline
post #2 of 5 (permalink) Old Dec 15th, 08, 09:27 PM
Re: Headlights
"correct procedure"?? They make a machine. You adjust it so it fits on the 3 nubs cast into the headlights. Turn the headlights on, and the machine tells you where to adjust them.
"What works for the rest of us"? Pull the car up close to a garage door (6") Turn on the lights, and put a masking tape "X" on the door in the center of each light. Back STRAIGHT away from the door as far as you can.
Adjust the headlights so the center of the beams is "a little bit" below and to the right of the "X"s on the door.
post #3 of 5 (permalink) Old Dec 15th, 08, 09:32 PM Thread Starter
Re: Headlights
OK. Thats a start. I'm installing Detroit speed head light conversion, and I know mine are currently out of adjustment. Wanted to get it right with the new lights..........Thanks
Black 69 camaro
post #4 of 5 (permalink) Old Dec 15th, 08, 09:36 PM
Dale
Send a message via AIM to Dale8346
Re: Headlights
http://www.ehow.com/how_112704_adjust-headlights.html
http://www.carinsurance.com/Articles/content169.aspx
http://www.lifespy.com/2007/how-to-a...rs-headlights/
http://www.automedia.com/Aiming_Head...cr20010801ha/1
I use to do it professionally with "gauges" that mounted on the lights and a level surface, etc. bla bla bla. But, really if you just have someone else drive you car towards you, everyone in their correct lane, it is really easy.
Most of us car guys know what they should look like. It takes some practice.
Just follow any of these procedures, then come at each other with 2 different cars, adjust, and do it again.
You will have it done today instead of trying to find someone that can do it better than you.
Dale8346 is offline
post #5 of 5 (permalink) Old Dec 16th, 08, 04:35 AM
Re: Headlights
Go to Daniel Stern Lighting and all the info for adj. is on the site
BigVin is offline
