coil PROB? - Team Camaro Tech
post #1 of 12 (permalink) Old Dec 19th, 08, 12:23 PM Thread Starter
robert
rolling-robert's Avatar
coil PROB?
hi,
my 355 is idling at 1500rpm, because i have a big camshaft in it, i cant set the idle lower then 1500rpm, or else it will die.
its idling okay at 1500rpm, BUT if my fans turn on, it will die.
I think it is because the coil gets too low voltage.
How can i fix that?
it should get 12volts, always, right?
thank you
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #2 of 12 (permalink) Old Dec 23rd, 08, 11:15 AM Thread Starter
robert
Re: coil PROB?
well, i think it should get 12 volts, but you can use a multi-meter to check.
you cant run a wire straight to the batttery, or else you wont be able to shut of the engine!!!
check your battery and your altenator also!!!
cya,
btw: awesome car you have and your great too!
Z28 1984
post #3 of 12 (permalink) Old Dec 23rd, 08, 11:33 AM
Banned
Ron
Badbird's Avatar
Re: coil PROB?
That's some pretty, weird funny stuff!.....You asked yourself a question then you answered yourself!!......And you even praised yourself!.....You must have a split personality or something!!.....Have a Happy Festivus Holiday!!
Badbird is offline
post #4 of 12 (permalink) Old Dec 23rd, 08, 01:40 PM
Will
Re: coil PROB?
I think somebodys been celebrating new years early.
Hatman is offline
post #5 of 12 (permalink) Old Dec 23rd, 08, 01:56 PM
Kevin
SixtyAte's Avatar
Re: coil PROB?
Originally Posted by rolling-robert View Post
hi,
How can i fix that?
thank you
Robert..
Looks like your post got lost here without anyone answering. The only time the coil gets 12 volts is at start up. Then it drops to about 6 volts. If you run a direct wire to the coil, you will burn it out if on too long. Sounds like you need to check for a vacuum leak also...
Kev
SixtyAte is offline
post #6 of 12 (permalink) Old Dec 23rd, 08, 02:31 PM
Will
Re: coil PROB?
Originally Posted by SixtyAte View Post
Robert..
Kev
Thats only if he has points ignition if he has HEI it should be 12 volts .
Hatman is offline
post #7 of 12 (permalink) Old Dec 23rd, 08, 04:22 PM
Charlie
Re: coil PROB?
We need to know what type of ignition he is running. Electronic gets full 12v. Points gets 12v at cranking and 6v during running.
67CamaroRS/SS is offline
post #8 of 12 (permalink) Old Dec 25th, 08, 06:10 AM Thread Starter
robert
Re: coil PROB?
its a h.e.i. ignition.
ill check how much volts it gets
Z28 1984
post #9 of 12 (permalink) Old Dec 25th, 08, 06:45 AM
Re: coil PROB?
It probably has nothing to do with the voltage, the HEI will start and idle a car on a fairly low voltage. If it's the cam in your signature, a 234° cam should idle well at less than 1000 rpm. What's your timing doing while the engine is dying? Got vacuum advance?
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #10 of 12 (permalink) Old Dec 26th, 08, 04:18 AM Thread Starter
robert
Re: coil PROB?
it is on a 106lsa basis!
i still have to change the plugs and reset my timing at 18-36 degrees.
but its do darn cold outside...
Z28 1984
post #11 of 12 (permalink) Old Dec 26th, 08, 08:05 AM
Re: coil PROB?
With 106° LSA, it will be hard pressed for smooth idling.
post #12 of 12 (permalink) Old Dec 27th, 08, 08:38 AM Thread Starter
robert
Re: coil PROB?
i know but the problem is that it idles much worse and even dies the moment the fans turn on.
Z28 1984
