Car Starts, but not through ignition - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 21st, 08, 03:01 PM Thread Starter
Hello, I a new owner to a 67' camaro and am trying to work some of the initial bugs out of it. So here is the history of this gremlin, hope someone can help me. The car will not start by the key ignition inside as normal, but will from a remote starter hooked to the solenoid.
I initially got the car and it was running and starting normally through the interior ignition switch. For some reason (this car has MSD ignition on it) the msd box 6AL went out. So I replaced it and car had spark again but I could not get it to start from inside with the ignition. So, I put my remote start on the solenoid and the car fired right up, no problem. So I initially thought the key ignition was bad so I replaced it. Still it will not start from inside through the keyed ignition, it will crank and crank but no fire. However, it will start with the remote. I am out of ideas, I hope someone can help me out. Thanks!
jcald is offline
post #2 of 8 (permalink) Old Dec 21st, 08, 03:49 PM
Brandon
Re: Car Starts, but not through ignition
check your ign fuse and see if it's burnt. Wire may need to be traced out to make sure its not cut or grounding. should go from switch to ign fuse at fuse block to msd box. If there is a resistor inline between the fuse and the msd you'll need to bypass it.
If the fuse is good and you have an ohm meter or test light.. turn the key to run and then check that you've got power going to the msd box.
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 8 (permalink) Old Dec 21st, 08, 07:25 PM
The 1967 ignition switch did not keep the IGN line hot during crank. That is one of the reasons for the yellow wire from the starter soleniod to the coil. During crank, the starter solenoid provides the coil with 12Volts. It's not uncommon for other model years to experience the same issue if a 67 ignition switch is used. 68 and 69 model years fixed the ignition switch problem, but retained the yellow wire for a hotter spark. Sounds like your yellow wire is missing.
dnult is offline
post #4 of 8 (permalink) Old Dec 21st, 08, 08:37 PM
Brandon
With the MSD 6 box the yellow wire from the solenoid to the coil goes away.. All power to the coil comes straight from the box on an orange wire and black for the ground side of the coil.
Nantooch is offline
post #5 of 8 (permalink) Old Dec 21st, 08, 08:39 PM
Check your neutral saftey switch and wiring
Musclerodz is offline
post #6 of 8 (permalink) Old Dec 22nd, 08, 03:27 PM Thread Starter
Thanks guys, I will run through the wiring tomorrow and let you know what I found. Like you said, there is no wire to the coil, the power all runs through the msd box. What about this neutral safety switch? This is a 4 speed, I have no experience with that at all. Any pointers on how to check it.
jcald is offline
post #7 of 8 (permalink) Old Dec 22nd, 08, 04:50 PM
Brandon
if its got the neutral safety switch, look for a pair of purple wires under the dash that drop down to the tranny on the drivers side. From what I recall, an NSS was not standard on a 67, but if the tranny was changed it may be there.
If it is there, it could be loose on the bracket or bad, only way to check is with a meter. Place the leads on either side of the switch and then depress the button on it that contacts the shifter arms and see if the button closes the circuit or not.
Nantooch is offline
post #8 of 8 (permalink) Old Dec 23rd, 08, 03:38 PM
THe NSS only affects cranking not running. If the starter motor spins, the NSS is fine. Focus on the ignition switch. Put a test lamp on the IGN terminal. Try to crank the engine. If the test lamp goes out the ignition switch is the problem. Either trade up to a 68 / 69 ignition switch or retain the yellow wire - regardless of the ignition type.
dnult is offline
Tags
electrical, ignition
