Changing-out Headlights on 69 RS/SS - Team Camaro Tech
post #1 of 11 (permalink) Old Dec 24th, 08, 01:14 PM Thread Starter
Chris
I was wondering if someone would help me with what steps are involved in removing the old 7" headlight and replacing it with a new 7" (Hella)? How do the old ones come out, connections, etc... Thanks!
1969 RS coupe Glacier Blue, GM HO 350 crate, 4-speed Muncie, ceramic Hooker headers, 3" Flowmasters, 10-bolt posi w/ 3/42's, Hotchkis suspension front/back, Bilstein shocks, multileafs, black factory interior, woodgrain dash, black Procar Rally seats.
chriss69 is offline
post #2 of 11 (permalink) Old Dec 24th, 08, 02:34 PM
Kurt
camsdad's Avatar
Re: Changing-out Headlights on 69 RS/SS
A chrome retaining ring and 3 screws hold the bulb in its mounting bucket.
Kurt
1969RS 14yrs into it.
383CID Lives
200R4 Trans, 3:42 Posi 12 Bolt Ready
Cold ones in the fridge. Dam, there gone. BRB
Getting closer to my goal.
camsdad is offline
post #3 of 11 (permalink) Old Dec 24th, 08, 03:10 PM Thread Starter
Chris
So...just out with the screws, out with the ring, disconnect the electrical and remove the light? That's it?
chriss69 is offline
post #4 of 11 (permalink) Old Dec 24th, 08, 03:22 PM
That's it! There are 3 retaining screws and 2 adjuster screws for L-R and U-D. When you unplug the old bulbs take a small double sided file (like an old points file) and run it in & out of the female connectors on the plugs to remove any corrosion. Then use a little dab of dielectric grease for a good connection and easy removal next time. If you really want those Hellas bright, run them through two relays for full 12v power to them. I re-did mine and it made a huge improvement.
redboots is offline
post #5 of 11 (permalink) Old Dec 24th, 08, 04:25 PM Thread Starter
Chris
redboots, are the Hella's not bright if I don't use the relays? How well do they work w/o the relays?
chriss69 is offline
post #6 of 11 (permalink) Old Dec 25th, 08, 06:56 AM
The headlight bucket assembly is held in with a spring hooked into it. Take a wire coathanger and bend the hook part straight out, then use a pair of pliers to make a small hook on the end. Use this hook to pull the spring off the headlight bucket. Pull the bucket off the adjusting screws. It will slide out of the slots in the screws. Disconnect the wire harness and then you can bring the assembly to a workbench and unscrew the trim ring from the bucket to remove the lamp. the lamp has tabs on it that fit into slots in the bucket so note how it came apart.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #7 of 11 (permalink) Old Dec 25th, 08, 11:52 AM Thread Starter
Chris
Thanks Mat. Still wondering if I need the relays redboots mentioned. Any input on that?
chriss69 is offline
post #8 of 11 (permalink) Old Dec 26th, 08, 12:52 PM
Fred
He's got it. I've been running Hella's for 30 years. They could be brighter. I don't run relays. They weren't invented back then.
128.79mph 1.428 60'
Fred Ficarra is offline
post #9 of 11 (permalink) Old Dec 26th, 08, 01:17 PM
A pretty good read here on relays
http://www.madelectrical.com/electri...adlights.shtml
BPOS is offline
post #10 of 11 (permalink) Old Dec 26th, 08, 05:52 PM Thread Starter
Chris
Thanks for the help .
chriss69 is offline
post #11 of 11 (permalink) Old Dec 26th, 08, 08:11 PM
Ed
BigBlock1969RS's Avatar
Planning on doing the same thing, replacing my old headlights with Hella halogens, going to use relays as well to ensure full voltage to the lights.
Ed
BigBlock1969RS is offline
