Need fusible links... - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 26th, 08, 02:25 PM Thread Starter
Marc
mnm99's Avatar
Where can I find a couple links with the correct ends? I need one for the voltage regulator and horn relay. Not sure what kind I need. One has a small orange wire link with a 10Ga wire. The other says 16Ga on the link wire and looks like 12Ga on the other end. I looked in the auto stores and and they have all the wrongs ends.
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #2 of 7 (permalink) Old Dec 26th, 08, 02:56 PM
Dave C
Re: Need fusible links...
You can get fusible links with fuzes in them at any amp you need if this will work for you.If they blow all you have to do is change the fuse.
PRO.ST69orange
post #3 of 7 (permalink) Old Dec 26th, 08, 04:04 PM
Make your own. The smaller gauge wire is four sizes smaller; ex. 12 GA uses 16 GA.
post #4 of 7 (permalink) Old Dec 26th, 08, 04:31 PM Thread Starter
Marc
mnm99's Avatar
Do you guys know what size link is connected to the regulator ? I can see the Horn relay one says 16Ga on the wire, but cant read the reg...It looks one like a 16 also I would guess.
mnm99 is offline
post #5 of 7 (permalink) Old Dec 27th, 08, 11:31 AM
Ted
Get them at MAD electronics.
tgifford5 is offline
post #6 of 7 (permalink) Old Dec 27th, 08, 03:10 PM Thread Starter
Marc
mnm99's Avatar
Thanks. I got a roll of 16Ga at my local autoparts.
mnm99 is offline
post #7 of 7 (permalink) Old Dec 28th, 08, 02:30 PM
Jereme
If it helps... I have attached a drawing that illustrates the correct fusible links for a stock installation. I believe that I lifted this from one of David Pozzi's posts, but can't remember.
Name:	ampmeter wiring.jpg
Good Luck
1969 L78 SS396 (Engine Long Gone)
BBC 496, TKO600, Beautiful Stock 12 Bolt Posi (maybe the only stock thing left.
RedJet is offline
