HEI ignition wire where is it? - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 27th, 08, 09:49 PM Thread Starter
Phil
Question HEI ignition wire where is it?
I'm about ready to start my new engine in my 67. I can't seem to find the ignition wire. I've got a new HEI distributor. The car didn't have a distributor in it when I bought it. The only spare wire I can find coming out of the wiring harness under the power brake booster is an orange wire but it doesn't have any voltage, ignition switch on or off. I understand that the orginal ignition wire should have a resistor and should put out about 6 to 8 volts, and I'll need 12 volts for the HEI. I found the starter wire and it works fine. The wiring diagram I have shows a purple wire for the ignition but I don't have one. I guess I could run a wire from the fuse box but I hate to. I know someone out there has an idea. Thanks!
phils67camaro is offline
post #2 of 7 (permalink) Old Dec 27th, 08, 10:52 PM
Re: HEI ignition wire where is it?
the stock coil wire should be covered in cloth- that's the wire that only puts out 6-8 volts with the key turned on.
if you find that wire, you could replace the whole wire up to the bulkhead with an HEI wire pulled from a car in the junkyard. it makes for a really clean install, and will only cost a couple of bucks, tops. of course, i don't know what kind of wiring bulkhead a 67 Camaro uses- GM switched the way they wired cars around that time- so you might need to put a different terminal on the wire.
you don't plan sincerity.
novaderrik is offline
post #3 of 7 (permalink) Old Jan 9th, 09, 09:29 PM
Jeremy
that car was designed to be for a points ignition system. i have the same orange wire on my 81. What u need to do is back track it to find the problem inside the dashboard. could be a broken connection. u never know what other people might have done with the car or how careless people could get. hope this helps.
]- Its legal unless you get caught. -[
jeremycam is offline
post #4 of 7 (permalink) Old Jan 9th, 09, 10:38 PM
Send a message via AIM to RamAirDave
You can run a wire directly from the IGN terminal on the fuse block under the dash to the BAT terminal on the HEI cap. I don't recall which gauge wire is needed (someone will know), but you don't want to skimp.
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #5 of 7 (permalink) Old Jan 10th, 09, 06:45 PM
That single orange wire coming out of the harness near the distributor is the power wire for the heater blower. Hope this helps you.
Harleyguy is offline
post #6 of 7 (permalink) Old Jan 10th, 09, 07:15 PM
Banned
Ron
Badbird's Avatar
This is exactly how I wired up an HEI on a 71 Malibu I once had!.....I used a length of 14 gauge wire.
Badbird is offline
post #7 of 7 (permalink) Old Jan 10th, 09, 08:52 PM
Larry
larryh56's Avatar
I would recommend #12 stranded MTW wire.
larryh56 is offline
