What size Alternator? - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 28th, 08, 11:04 AM Thread Starter
Clint
I will be wiring my car soon and I was looking for alternator amperage recommendations. I would like to run options such as: vintage air, power windows, stereo system, etc. I will be using the AAW classic update wiring harness. I was thinking a 100 amp alternator, does this sound ok or should I go bigger? Thanks.
Clint
cwb90 is offline
post #2 of 3 (permalink) Old Dec 29th, 08, 09:45 AM
Re: What size Alternator?
You can do your request. If you decide to go with external regulated Delcotron alternator(OE supplied), use a Wells VR715 reg and have AAW install #8 AWG supply wire rather than #10 AWG.
If you decide on internal regulated, 12SI, or CS130, have AAW set-up the harness for the alt chosen and still replace the power wire for #8 AWG.
post #3 of 3 (permalink) Old Dec 29th, 08, 06:43 PM
IMHO there is no reason not to use a CS style. CS-130 is typical. Look in the stickies at the top of the electrical forum. You'll find some posts there and in the technical reference series (accessable from a couple of the sticky posts and the index page of this site). There are some brackets involved in mounting up a CS-130. Also the "clock position" of the mounting bosses is something to consider before you purchase.
dnult is offline
