I need your opinion guys! - Team Camaro Tech
post #1 of 16 (permalink) Old Dec 30th, 08, 04:47 PM Thread Starter
Marc
mnm99's Avatar
I started a new project this weekend. I'm relocating the voltage reg, horn relay and the 2 headlight relays on the drivers side to the mounting plate I fabricated. I'm taking them off the radiator support. My question is. I installed all new connectors and fusible links. Every connection is grimped, soldered and heat shrunk.The plate that you see will be able to come off real easy with 2 bolts. Should I mount everything out of site on the inside of the plate( inner fender) or keep them on the outside (engine comp)? It would look much neater on the inside, but there are 2 fusible links in there also. I'm sure I could protect the other wires with electrical tape and loom if I had to. All you would see would be bolt heads. Would I have problem with heat in the inner fender? I would think it would be cooler.
On the pass side I have 2 realys for the fans that have 2 , 20a fuses that I would need access to if they blew. Once again 2 bolts and the panel will come right off.
What do you think I should do?
Oh before anyone asks....I need the space on both sides of the radiator for the intercooling tubes
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #2 of 16 (permalink) Old Dec 30th, 08, 06:48 PM
Tony
Thumbs up Re: I need your opinion guys!
I did something similar but I had originally had mine on the Engine side and then when I rewired the car I bolted the panel on with a piano hinge and I now tuck it away until I need to access it or want to show it off.
Tony:
67 RS Clone, 388 SBC/Keisler TKO 600/12 bolt, 3.90 gear w/posi and a 250 shot of N2O for fun. See my progress at: password is camaro
idoxlr8 is offline
post #3 of 16 (permalink) Old Dec 30th, 08, 07:23 PM
I like it, and would not have any problem hiding the stuff behind those panels.
post #4 of 16 (permalink) Old Dec 31st, 08, 05:45 AM Thread Starter
Marc
mnm99's Avatar
You don't think I'll have a problem huh. I have a bunch of Fatmat left. I think I'm going to line the whole inner fender area just to make sure no wires are rubbing on anything. I have an idea how to mount it all without seeing the bolts on the outside. I'll post pics...
Happy new year..... Wow weather just said 3-6 inches of snow...Wonderful!
mnm99 is offline
post #5 of 16 (permalink) Old Dec 31st, 08, 08:26 AM
prostreet69camaro's Avatar
I would also mount the relays on the back side. Only problem I would see is which way do you put the screws in. I would put the screw head towards the engine bay side and the nuts on the relay side. It would look nicer if it was smooth on the engine bay side.
I mounted my relays on the flat side of the wheel tub where the blinker light cable goes thru the tub. I like the plate better though.
prostreet69camaro is offline
post #6 of 16 (permalink) Old Dec 31st, 08, 10:17 AM Thread Starter
Marc
mnm99's Avatar
I'm going to mount eveything on the inside. I started fabricating a couple of pieces. There isn't enough room to fit all the stuff on the backside, but I figured out a way. And all the bolts are getting the heads welded to the backside. It will look nice and smooooth when I'm done.
mnm99 is offline
post #7 of 16 (permalink) Old Dec 31st, 08, 01:31 PM
Fred
I like it too. Just might end up on my Camaro. This work reminds me of my sailboat wiring I did a couple of years ago. This is the control panel.
Closed up.
inside
Too much fun!
128.79mph 1.428 60'
Fred Ficarra is offline
post #8 of 16 (permalink) Old Dec 31st, 08, 03:29 PM
Dave C
Doesn't this run on wind,so what are all the wires for....
PRO.ST69orange
post #9 of 16 (permalink) Old Dec 31st, 08, 04:18 PM Thread Starter
Marc
mnm99's Avatar
Go ahead tell him ....LOL
mnm99 is offline
post #10 of 16 (permalink) Old Dec 31st, 08, 04:35 PM
Fred
I forget.
128.79mph 1.428 60'
post #11 of 16 (permalink) Old Dec 31st, 08, 04:39 PM
Fred
OK. A little later view. I'm trying to recall,,,,,,,
128.79mph 1.428 60'
post #12 of 16 (permalink) Old Dec 31st, 08, 06:35 PM
Damn Fred you are forgetting alot when you get old.LOL
Your panel looks nice. I used to wire panels for offshore when I was younger. Now I sit behind a computer.
post #13 of 16 (permalink) Old Jan 1st, 09, 11:28 AM Thread Starter
Marc
mnm99's Avatar
Here's some more progress. I have to bring it to powdercoating next.
mnm99 is offline
post #14 of 16 (permalink) Old Jan 1st, 09, 02:14 PM
Looks like a good idea.... might steal it .... hope you don't mind.
68 Camaro~LSx ~all motor
post #15 of 16 (permalink) Old Jan 2nd, 09, 11:35 AM
Tony
Very Nice work. Looks better than my idea!
Tony:
idoxlr8 is offline
