New Wire Harness Problems - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 31st, 08, 09:53 AM Thread Starter
Dwayne
I have installed a new front wire harness on my 67 rs convertible and now I can start the car, but turning it off doesn't work with the key. Fortunately, I have a manual trans. Does anyone know how to check this out? The old harness worked fine (in that area anyway). I still have the problem with the tach, but that's not as important as shutting off the car! Any help would be GREAT!
DeweySport is offline
post #2 of 6 (permalink) Old Dec 31st, 08, 12:10 PM
Christropher
Re: New Wire Harness Problems
Sounds like the wire to your distributor is getting full time power off the battery instead of power through the ignition.
Christropher
...in pieces still.
clwilcox33 is offline
post #3 of 6 (permalink) Old Dec 31st, 08, 12:30 PM Thread Starter
Dwayne
hmmm, that's a thought. Although, I haven't changed anything there. I will look into that. I don't think that would have anything to do with the tach since it's connected to the coil, do you? I still have an original distributor with points, though I have given serious thought into getting a new distributor. I will try to double check the wiring leads. Thanks for the response.
post #4 of 6 (permalink) Old Dec 31st, 08, 12:32 PM
Christropher
I can't pretend to know electrical systems at all as i don't. I just responded with something I would think about checking, and in process, bumping your post hoping someone w/ more knowledge than I would respond as well. Good luck!
Christropher
...in pieces still.
post #5 of 6 (permalink) Old Dec 31st, 08, 12:39 PM
With points dist installed, make sure the yellow wire on the solenoid is on the "R" terminal and on the + coil terminal.
Green tach wire should be on - coil terminal.
If you have a 10SI or 12SI (internally regulated alternator), you need the diode installed to kill the excitation to kill the electrical system to stop the engine.
post #6 of 6 (permalink) Old Dec 31st, 08, 08:38 PM Thread Starter
Dwayne
Thank you both. I've had my restoration going for some time and it's always something else in line to fix. I just found this site and signed up and am impressed as well as grateful. I'll troubleshoot some more and plan on being a regular to this site!
Thanks again.
