69 Camaro RS Back Up Light Question - Team Camaro Tech
post #1 of 12 (permalink) Old Dec 31st, 08, 07:13 PM Thread Starter
I hope I am posting this in the right section but here it goes.I need to know where to drill the hole in the trunk to hook up the wire for the RS back up lights,non orig RS car ? I have the correct RS tailight wire harness.I tried to search on here and CRG but only found one picture on DJD's pictures and could not tell for sure where to drill.Team Camaro is a killer site with lots of good info,been lurking for quite awhile.Thanks mj
LOTSARIDES is offline
post #2 of 12 (permalink) Old Dec 31st, 08, 07:31 PM
Larry
Re: 69 Camaro RS Back Up Light Question
I believe there was a rubber gromment that went through the trunk floor under the bumper? Don't know for sure, but someone with a 69 from here will get ya to the right place.
Sometimes it's better to let someone think your an idiot, than to open your mouth and remove all doubt...
ls427ss is offline
post #3 of 12 (permalink) Old Dec 31st, 08, 07:53 PM Thread Starter
Larry thanks for responding,I do have the rubber grommet and the correct wire plug in.I have already cut the valance and I have pretty good general idea where to drill the hole but I want it to be in the correct spot.Thanks mj
post #4 of 12 (permalink) Old Dec 31st, 08, 09:55 PM
Jeff
yellow69RS's Avatar
I'm glad you asked! Cuz I need to know also. I have replaced the trunk floor and no befroe pics or notes to go by. I think I know but would like someone to varify.
Jeff
yellow69RS is offline
post #5 of 12 (permalink) Old Dec 31st, 08, 11:33 PM
Send a message via AIM to RamAirDave
Between the quarter and the bracing. There should be a half-circle cutout in that brace. Thats where the grommet for the wire goes
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #6 of 12 (permalink) Old Jan 1st, 09, 11:28 AM
click's Avatar
Here is the hole for my RS backup lights
click is offline
post #7 of 12 (permalink) Old Jan 1st, 09, 11:44 AM Thread Starter
A BIG THANKS !!! That is exactly the picture I needed.I would had put the hole on the wrong side of the brace.Excellent SITE !!! Have a wonderful New Year ! mj
post #8 of 12 (permalink) Old Jan 1st, 09, 03:17 PM
Jeff
yellow69RS's Avatar
Thanks for the pics, guys!
Jeff
post #9 of 12 (permalink) Old Jan 27th, 12, 06:24 AM
Adam
Can I use my backup light wiring from the middle bulb in conventional rear taillights?
1996jeep is offline
post #10 of 12 (permalink) Old Jan 27th, 12, 07:11 AM
Kevin
KevinW's Avatar
Yes, but if you are keeping the standard lens, why would you add the RS backup lights?
RS taillamps had different lenses, housings, backup lights and wiring harness. Only changing one peice causes issues someplace else.
Kevin
KevinW is offline
post #11 of 12 (permalink) Old Jan 27th, 12, 09:57 AM
The rs backup light comes with a female spade connector and grounds at the body.. I converted my standard harness by soldering and heat-shrinking a male spade onto the hot wires for b/u lights.
To convert your rear light harness correctly for 69 rs, you will also need to to add 1157 type sockets to the inner spot on each tail light housing, so that both the outer and inner on each side have tail, brake & turn.
Or just buy a rs rear light harness.
The rs tail light lens will fit your standard housing, however to be absolutely correct, the rs housing does not have a socket hole in the center pod.
BPOS is offline
post #12 of 12 (permalink) Old Jan 29th, 12, 05:30 PM
Adam
when you converted your standard harness- did you just pull the light green wire out of the middle socket, put a male on and connected?
My middle socket has a black wire still in it- is that okay to leave in there?
1996jeep is offline
