where can I find a sealed 30 amp relay - Team Camaro Tech
post #1 of 11 (permalink) Old Jan 4th, 09, 04:18 PM Thread Starter
I am looking for a couple of relays for my project. The current need is for the neutral safety switch on my TKO. I am going to tie it in to the two heavy purple wires. I figure I may also wire in a pair of relays for the headlights. Already have the Spal relay kit for their radiator fans, its nice.
My problem is I can't find a chart or part number with a detailed description as to whether the relay is sealed or not, amp rating, or any other specs for that matter.
Everything I have seen says to use a "sealed 30 amp Bosch relay" or whatever. Try telling that to the dweeb behind the counter at your local parts store.
I would like to find a local source, but I guess I could order relays too, I have had to mail order everything else.
Chris
cm-67 is offline
post #2 of 11 (permalink) Old Jan 4th, 09, 04:44 PM
Coppertop's Avatar
Re: where can I find a sealed 30 amp relay
Chris-
This is Coppertop, the electronics guru from Team Chevelle. I'll try to dig up some part numbers for you, but I think I have an idea on exactly what you should get. I do a lot of custom work on my '70 (Chevelle), so I like to build stuff from scratch using top-notch stuff, not the generic crap that the auto parts places sell.
I get a lot of my stuff from Mouser Electronics in Texas. They have NO minimum order. I got some SEALED relays (they are Masu****a--Parent company of Panasonic), with diode suppression across the coil, top quality--that would be the way to go. I'll look for the part number. Price was not bad at all.
-Joe
Coppertop is offline
post #3 of 11 (permalink) Old Jan 4th, 09, 05:27 PM Thread Starter
Coppertop,
Thanks for the speedy reply. That sounds like what I am looking for, especially if they are available with the diode across the coil (although I have been told it is not needed for what I am doing, anything to prevent voltage spikes and increase the life of the relay is better in my book).
I guess instead of getting multiple different amperage ratings, I could just get a bunch of 45 amp relays or so that would cover each circuit, 2 for the headlights, 1 for the nss, 1 for the fuel pump and so on so that I can keep a spare around and just swap out for the individual relay that goes bad. Just in case.
Chris
cm-67 is offline
post #4 of 11 (permalink) Old Jan 4th, 09, 05:56 PM
May want to look in your local boat supply company too ?
68 Camaro~LSx ~all motor
post #5 of 11 (permalink) Old Jan 4th, 09, 09:12 PM
Coppertop's Avatar
Found my old receipt...
Here's the link at Mouser:
Panasonic Automotive Relay
If you buy this, make sure you wire the relay's coil correctly as it has a diode built in, wire it wrong and the relay becomes a dead short! 85 = ground 86 = +12 v relay coil power!
post #6 of 11 (permalink) Old Jan 5th, 09, 09:50 AM
Snodgrass
Good prices on 12-volt relays at Parts Express:
http://www.partsexpress.com/pe/showd...number=330-070
snodgrass is offline
post #7 of 11 (permalink) Old Jan 5th, 09, 10:03 AM
Harley uses a sealed 30 amp relay in the starting circuit.
Stainless dog is offline
post #8 of 11 (permalink) Old Jan 5th, 09, 10:08 AM
BILL
SPARKY69's Avatar
Napa
SPARKY69 is offline
post #9 of 11 (permalink) Old Jan 5th, 09, 10:39 AM
A sealed relay will have a sealed connector, also. You can find these relays, like the GM 25553347, under the hood of many GM cars.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #10 of 11 (permalink) Old Jan 5th, 09, 11:04 AM
Larry
napa auto parts has several different amp relays, diode protected ones and plug in pig tails for the wiring
Sometimes it's better to let someone think your an idiot, than to open your mouth and remove all doubt...
ls427ss is offline
post #11 of 11 (permalink) Old Jan 5th, 09, 03:50 PM Thread Starter
Lots of good sources guys. Thank you very much.
Chris
cm-67 is offline
