quick (maybe stupid) question - Team Camaro Tech
post #1 of 17 (permalink) Old Jan 10th, 09, 08:44 AM Thread Starter
keypilot's Avatar
on my 67, when the turn signal is on and i step on the brake shouldnt the non flashing tail light light up?
i just changed my std lenses to RS lenses and added a socket (reverse lights were not hooked up anyway)
the thing is, i cant remember if it was the same way before i added the inboard sockets.
normal other than that. running lights and blinkers work correctly.
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
499 lb-ft @ 4,800 rpm
keypilot is offline
post #2 of 17 (permalink) Old Jan 10th, 09, 10:29 AM
erik
Re: quick (maybe stupid) question
Yes it should light up. Do the brake lights work when the turn signal isn't on?
tumper is offline
post #3 of 17 (permalink) Old Jan 10th, 09, 10:59 AM
Charlie
Maybe you accidently tapped into the back up light wires by mistake? Honest mistake.
67CamaroRS/SS is offline
post #4 of 17 (permalink) Old Jan 10th, 09, 01:55 PM Thread Starter
keypilot's Avatar
erik, brake lights work normal with the parking lights on or off. it is only when i use the turn signal that i have that problem.
charlie, it is not tapped into the back up lights.
the aftermarket socket has a black and white wire. the right side is green to white and the left is yellow to white both sides are brown to black. its pretty straight forward.
did i miss something?
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
keypilot is offline
post #5 of 17 (permalink) Old Jan 10th, 09, 02:28 PM
Jeff
yellow69RS's Avatar
Sounds like it might be a bad turn signal switch. Check for power on the wire opposite the side the T/S is on at the T/S switch. (turn on rt turn check green wire at sw with brake pedal depressed)
Jeff
yellow69RS is offline
post #6 of 17 (permalink) Old Jan 10th, 09, 03:20 PM
prostreet69camaro's Avatar
Are you using the 1156 or 1157 bulb.
The turn signal / brake light socket is a 3 wire socket.
The back up or brake light socket is a 2 wire socket.
I dont know if it the same on a 67. I am talking about a 69. Just a thought, maybe the wrong socket and you need the 3 wire socket for the 1157 bulb.
prostreet69camaro is offline
post #7 of 17 (permalink) Old Jan 11th, 09, 09:25 AM Thread Starter
keypilot's Avatar
they are 1157 bulbs. there are only 2 wires in the harness (other that reverse wires)
the yellow and green are t/s and brake and brown is running lights. ground it through the housing. if this is wrong please tell me.
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
keypilot is offline
post #8 of 17 (permalink) Old Jan 11th, 09, 09:32 AM
Skip
Skeeter55's Avatar
I thought it needs to grounded in the trunks (trunk pan nearest tail lights)... I think on my 69 that the Dark Grey (passenger side) and the Yellow on the (driver side) are the turn signal leads. Did you try a test light, could be a bad bull.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #9 of 17 (permalink) Old Jan 11th, 09, 10:22 AM
Matt
See if this helps. This is a 68 (RS clone) and I just relocated my backup lights. My tail lights/brakes/turn-signals seem to all agree with each other. I installed new sockets that came with white and black wires. Just did this over the weekend and haven't covered the wires up with harness tape.
zlek131 is offline
post #10 of 17 (permalink) Old Jan 12th, 09, 08:23 AM
Matt
Woops...appears some can't see pics in my posts. I included a pic in my reply to you. Let me know if you can't see the pic and I will email it to you.
Matt.
zlek131 is offline
post #11 of 17 (permalink) Old Jan 12th, 09, 08:31 AM Thread Starter
keypilot's Avatar
i can see it matt, thanks. but that is exactly the way i did mine. i didnt have a chance to mess with it yesterday but i will tonight.
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
keypilot is offline
post #12 of 17 (permalink) Old Jan 17th, 09, 10:33 AM Thread Starter
keypilot's Avatar
arrgg!!!! this brake light thing is driving me nuts.
does the brake light circuit run through the TS switch? so if my TS switch is bad the non flashing side may not lite up while turning? i went through everything with a test lite and get the same results.
i dont want to get ***-ended trying to turn off the hwy.
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
keypilot is offline
post #13 of 17 (permalink) Old Jan 17th, 09, 11:02 AM
Turn signal rule over stop lights. Use a heavy duty flasher, 552(?), as this flasher will flash without having a load, light bulbs, in place as with a 512 flasher.
Emergency flashers over rule all. And yes, stop light goes through ts switch.
post #14 of 17 (permalink) Old Jan 17th, 09, 01:01 PM Thread Starter
keypilot's Avatar
i checked the flasher, it is a 552. thanks Everett
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
keypilot is offline
post #15 of 17 (permalink) Old Jan 17th, 09, 02:19 PM
Brett
My 67 rs both lights blink when the signal is on.
Brett
gm torch red is offline
