Low Fuel Light - Team Camaro Tech
post #1 of 16 (permalink) Old Jan 10th, 09, 06:30 PM Thread Starter
Banned
Alan
98blackburb's Avatar
Low Fuel Light
I have a 1969 SS, Factory Console gauges.I understand the yellow wire goes back to the main connection which goes to the the dash low fuel light,but where does this light go to that came with the harness, Into one of the holes in the console ???
98blackburb is offline
post #2 of 16 (permalink) Old Jan 10th, 09, 06:52 PM
"Tri-Tip"
Gary L's Avatar
Re: Low Fuel Light
There is not supposed to be a light bulb in the low fuel module. Each gauge has it's own bulb.
Gary L is offline
post #3 of 16 (permalink) Old Jan 10th, 09, 07:01 PM Thread Starter
Banned
Alan
Re: Low Fuel Light
Thanks Gary, I kind of remember hearing that now, but ,where does this go ? It came with an aftermarket harness from Rick's. I am stumped because it came with it.Is the bulb a type of fuse?It has tits on the housing like it gets plugged in somewhere?
post #4 of 16 (permalink) Old Jan 10th, 09, 09:02 PM
Russ
rafbody's Avatar
Re: Low Fuel Light
On a 67 with console guages and tach, there is a low fuel light in the speedometer on the lower right area. I suspect that a 69 might be similar.
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
rafbody is offline
post #5 of 16 (permalink) Old Jan 10th, 09, 09:32 PM
Re: Low Fuel Light
On a 69 the low fuel light is a warning light in the dash.
Captain
Destin Fire
I'm sick and tired of mismanagement and disappointment. I'm a Cowboys fan
WYKOFF69Z is offline
post #6 of 16 (permalink) Old Jan 10th, 09, 10:07 PM
Re: Low Fuel Light
Found this on the CRG site.
http://www.camaros.org/forum/index.php?topic=1580.0
Captain
Destin Fire
post #7 of 16 (permalink) Old Jan 10th, 09, 10:57 PM
"Tri-Tip"
Gary L's Avatar
Re: Low Fuel Light
Right, but no light in the module.
Gary L is offline
post #8 of 16 (permalink) Old Jan 12th, 09, 06:45 PM
Re: Low Fuel Light
Yeah, that little socket is molded to the end of the low fuel warning module to keep it from rattling around in the console. It plugs into the big hole right beside the fuel terminals with no light.
StrykerCamaro is offline
post #9 of 16 (permalink) Old Jan 12th, 09, 06:48 PM Thread Starter
Banned
Alan
Re: Low Fuel Light
So If I understand you right ,next door to where the oil pressure fitting is?
post #10 of 16 (permalink) Old Jan 13th, 09, 07:29 AM
click's Avatar
Re: Low Fuel Light
I just taped mine against the back side and it sits there fine. No bulb in it, as mentioned.
click is offline
post #11 of 16 (permalink) Old Jan 13th, 09, 11:37 AM Thread Starter
Banned
Alan
Re: Low Fuel Light
Thanks Jim,sent you a PM
post #12 of 16 (permalink) Old Jan 13th, 09, 12:10 PM
click's Avatar
Re: Low Fuel Light
The AIM doesnt show the low fuel module that I can see, but shows some wires going thru the larger hole somewhere.
click is offline
post #13 of 16 (permalink) Old Jan 13th, 09, 12:37 PM
DjD
DjD's Avatar
Re: Low Fuel Light
How come you didn't plug it into the hole Jim?
...Dennis
DjD is offline
post #14 of 16 (permalink) Old Jan 13th, 09, 12:59 PM
click's Avatar
Re: Low Fuel Light
I dont recall why but thought it may show thru to the other side? ugly then? I just didnt.
click is offline
post #15 of 16 (permalink) Old Jan 13th, 09, 01:47 PM Thread Starter
Banned
Alan
Re: Low Fuel Light
OK guys, I just got off the phone with the boys at Ricks. I sent them a picture and they researched it and told me that no bulb goes in that and it tapes to the back just as Jim has it in his picture,Evidentally that same harness is used on the Corvettes and needs the bulb, but not on the Camaro. The yellow wire sends the Low Fuel signal to the Dash Indicator.
Thanks for all your help................alan
