AAW wiring to the battery - Team Camaro Tech
post #1 of 14 (permalink) Old Jan 10th, 09, 06:48 PM Thread Starter
I just wanted to confirm the battery connection with those that have done the Classic Wiring Update. According to what I am reading in the directions, there is no more junction box and no more horn relay next to the radiator. Just a red (going to the alternator) and a brown (going to the bulkhead connector) attached to the batttery terminal on the starter. Since thats quite a bit different, I wanted to make sure I am reading it correctly.
thanks
wheezer is offline
post #2 of 14 (permalink) Old Jan 10th, 09, 10:26 PM
Todd
Re: AAW wiring to the battery
Should have a fusible link and red wire to the alternator and yes a main power wire to the fuse block.(not sure on color) I can dig out my diagram if needed.
Vegas69 is offline
post #3 of 14 (permalink) Old Jan 11th, 09, 09:24 AM
Ed
BigBlock1969RS's Avatar
Fusible links are messy, I'd use regular fuse if possible, much easier to replace if ever needed.
I'm planning on adding a small fuse box in the rear of my car for Fuel pump, stereo (B+ keep alive), alternator etc and a couple other expansion slots for the future.
Ed
BigBlock1969RS is offline
post #4 of 14 (permalink) Old Jan 11th, 09, 11:02 AM
Todd
The alternator is the only wire with a fusible link on the new harness. Suppose due to high amperage. I have found there to be plenty of power feeds off the fuse block. I still have 2 unused. I did use my bulkhead at my firewall for my MSD box power since there is an internal circuit breaker, I also used it for the alternator instead of cobbling up the starter, and the main power for the fuse block. Basically the wires are in parralel from the bulkhead. The amp is wired from the battery in the trunk with circuit breaker and the remote wire to turn on the amp comes from the radio. I ran my fuel pump relay trigger with my tail light wiring and the main power, and two grounds to the battery wince it's back there. The relay is right on the trunk latch tower.
Vegas69 is offline
post #5 of 14 (permalink) Old Jan 11th, 09, 01:16 PM
I disagree. Trying to find a fuse and holder capable of handling more than 50 amps makes fuses an expensive option. Fusable links have their place and this is one of them IMHO.
dnult is offline
post #6 of 14 (permalink) Old Jan 11th, 09, 03:03 PM
NHBandit's Avatar
I'm using the Classic update kit as well and have it all hooked up exactly the way they show it as far as the starter, alternator, ignition, etc. and it will not turn over with the key. The front & rear light wiring hasn't been done yet but all the engine wiring and under dash wiring to the ignition is in place. Am I overlooking something simple ? (yes I did put the fuses in the fusebox)
NHBandit is offline
post #7 of 14 (permalink) Old Jan 11th, 09, 03:42 PM
Ed
They have some really nice high amp fuses called Maxi or Bussman fuses, available from 20 amps all the way to 300 amps:
http://order.waytekwire.com/scategory/M37/140/500
(250amp fuse shown)
If you ever had to replace a fuseable link you definitely wish there were other options and there are. Used some of the Maxi fuses when I wired up the engine stand to break in my motor really nice stuff, definitely worth looking into over fusable links.
Ed
post #8 of 14 (permalink) Old Jan 11th, 09, 06:28 PM
AAW has some of those fuses available
Musclerodz is offline
post #9 of 14 (permalink) Old Jan 11th, 09, 07:33 PM
Isn't the main power wire for the fuse block routed from the front light harness? (at least it is on the factory harness)
1969SSBB is offline
post #10 of 14 (permalink) Old Jan 11th, 09, 07:52 PM
NHBandit's Avatar
That would explain why I can't crank mine over with the key. I'll have to look into it more. Got wrapped up in bodywork & paint and got away from the wiring for awhile.
NHBandit is offline
post #11 of 14 (permalink) Old Jan 11th, 09, 08:36 PM
Todd
Is it a classic update kit or factory style?
Vegas69 is offline
post #12 of 14 (permalink) Old Jan 11th, 09, 08:46 PM
NHBandit's Avatar
Mine is the Classic update kit for a 67
NHBandit is offline
post #13 of 14 (permalink) Old Jan 11th, 09, 08:49 PM
Ed
Oh, that is good to know.
Ed
post #14 of 14 (permalink) Old Jan 12th, 09, 04:52 AM
thanks
Yes, that's the way the Update gets wired. I ran the heavy gage red alternator/charging feed wire from the starter back to the firewall (with the leads coming down to the starter), under the heater box cover (I just added a couple of extra clips like the one that holds the orange heater fan lead on top of the box), over the inner fender behind the outer fender, and then out from the battery area with the alternator light lead and ground wire.
AAW did explain to me why they chose to charge the battery through the starter connection (instead of going to the junction block behind the battery and then to the positive terminal), but the reasoning escapes me right now. If you're curious, give Donny Bock at AAW a call or email, and he can explain it.
Eric
Eric Kammerer is offline
