Cowl Induction Throttle Switch - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 12th, 09, 07:39 AM Thread Starter
This should be a simple process but I seem to be having problem installing the switch. Do you put the switch mount clip on the switch and then push it through the throttle arm? Or do you but the switch on the throttle arm and put the clip on from the back side? I have pictures of it both ways. I also don't know how far the switch should be pushed in to the throttle arm. My Throttle arm is already attached and I really don't want to take it back off. Thanks!
nooney is offline
post #2 of 3 (permalink) Old Jan 12th, 09, 08:59 AM
Re: Cowl Induction Throttle Switch
Put the retainer clip on the switch and snap it in the hole. As for adjustment, it will do that by itself when you depress the pedal. Don't push it to far in the clip when installing it.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
post #3 of 3 (permalink) Old Jan 13th, 09, 05:18 AM Thread Starter
Thanks Steve!
nooney is offline
