CS130 Alternator - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 12th, 09, 01:03 PM Thread Starter
Daral
CS130 Alternator
Which CS130 Alternators bolt right up to stock brackets on a 67 small block (short water pump, alternator on drivers side). My heads don't have accessory holes so I am guessing the Duralast (DLG1345-6-7) in Wes Vann's article probably will not work on my stock brackets.
Daral (67 RS/SS 350)
Daral is offline
post #2 of 7 (permalink) Old Jan 13th, 09, 09:50 AM Thread Starter
Daral
Re: CS130 Alternator
Maybe I should have asked this in the Engine forum? I am sending in an order for engine parts and wanted to include a new Alternator.
Daral is offline
post #3 of 7 (permalink) Old Jan 13th, 09, 10:04 AM
Paul
I used an alternator from a 90-93 chevy pickup 1 ton dually with a 454...
But I have this bracket:
http://www.alangrovecomponents.com/i...sions/215R.GIF
Best of 1.55 - [email protected]
paulm is offline
post #4 of 7 (permalink) Old Jan 13th, 09, 10:38 AM Thread Starter
Daral
Thanks Paul. Wrong bracket and wrong side of the engine. I am trying to keep mine looking stock eventhough I am upgrading to a CS130.
Daral is offline
post #5 of 7 (permalink) Old Jan 13th, 09, 10:51 AM
Paul
I'm wondering if it would work though...if you rotate my alternator 180 degrees and put it on the drivers side, it lines up, no?
Here is the stock engine compartment:
http://www.stratagaz.com/67L30M20/L30M20-NewPaint06.jpg
paulm is offline
post #6 of 7 (permalink) Old Jan 13th, 09, 11:15 AM Thread Starter
Daral
I see what you mean, that might work. Did you have to change the pulley?
Daral is offline
post #7 of 7 (permalink) Old Jan 13th, 09, 11:28 AM
Paul
Yes, came with a serpentine or whateveryoucallit pulley so I swapped it with the alternator that I had. Took about 30 seconds with my little cordless impact.
paulm is offline
