Wiring for 69 headlight washer pump - Team Camaro Tech
post #1 of 17 (permalink) Old Jan 16th, 09, 12:17 PM Thread Starter
I am looking for info and/or pics for headlight washer pump wiring. Do you just make a jumper from the other pump wires ? If so how does it connect into the original harness and still look correct ?
Cliffs Cars Restoration is offline
post #2 of 17 (permalink) Old Jan 16th, 09, 12:31 PM
click's Avatar
Re: Wiring for 69 headlight washer pump
Cliff, Im moving this to your same question in Elec. section. You only need to post in one area, as that is our site policy too.
Is it an RS camaro? Those have 2 solenoids, one on top of the wiper motor and one underneath....
this is the RS setup:
click is offline
post #3 of 17 (permalink) Old Jan 17th, 09, 10:26 AM Thread Starter
Ours is not an RS but it looks the same except our solenoid does not have the hose coming out of the end. Just the two hoses at the pump. Do you know where I could get the ends to connect the wires to the pump terminals and also hook up the jumpers ? The pic looks like a end with 1 female term. and 2 males made together.
post #4 of 17 (permalink) Old Jan 17th, 09, 12:24 PM
Fred
Cliff, NOT an RS?? And it has the white pump? This is original RS.
Let us know if you need a better look.
128.79mph 1.428 60'
Fred Ficarra is offline
post #5 of 17 (permalink) Old Jan 18th, 09, 08:37 AM
click's Avatar
By 'ends' do you mean the brown plastic parts that the wires end up inside? Those are available at body shops or any parts store... still not clear what you have there either. If you have a solenoid on top of your wiper motor, that is an RS setup. Check the number on the end of the wiper motor, that will tell us if its RS or standard.
click is offline
post #6 of 17 (permalink) Old Jan 18th, 09, 09:42 AM
DjD
DjD's Avatar
There were 116 Non-RS cars that got the RPO-CE1 Headlight washers. Sounds like Cliff's got one.
...Dennis
DjD is offline
post #7 of 17 (permalink) Old Jan 18th, 09, 10:28 AM
click's Avatar
good catch Dennis that might be exactly what he has.
click is offline
post #8 of 17 (permalink) Old Jan 18th, 09, 11:15 AM
Jeff
yellow69RS's Avatar
Talk about rare! I had forgotten that was offered separately, very good catch.
Jeff
yellow69RS is offline
post #9 of 17 (permalink) Old Jan 19th, 09, 11:47 AM
Fred
Yep. The headlight washers were available separately. I thought they were silly. I guess most folks did too, except for 116.
128.79mph 1.428 60'
post #10 of 17 (permalink) Old Jan 19th, 09, 05:24 PM
mark
mark x22's Avatar
here's a picture without the brown connector , ricks has the wires .
1969 Rally Sport (RS) Headlight Washer Pump Wiring Harness
Camaro Headlight Washer Pump Wiring Harness, Rally Sport (RS), 1969
Item# 97543
$14.99 ea.
mark x22 is offline
post #11 of 17 (permalink) Old Feb 5th, 13, 08:31 PM
George
Papa's Avatar
Hi All
Ok by reading this post I have worked out that the small pump on top of my washer/wiper motor is used for the head lights.
My question now is does anybody have a drawing or pictures on how to connect the water lines/tubing I had one of my buddies help restore the engine bay and when he removed it we some how lost the tubing and now don't know how it all should fit back in and or what goes to the main water tank, all I have is the water spray nozel for main windscreen I don't even know where the head light spray head go.
Your help would be appreciated
69 RS X11 Cortez Silver 383 Stroker
Papa is offline
post #12 of 17 (permalink) Old Feb 5th, 13, 11:58 PM
Tim
George, if you have a 69 AIM, the headlight washer hose arrangement is shown in UPC CE1, sheet A2 (standard headlight cars) and UPC Z22, sheet B11 (RS option).
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #13 of 17 (permalink) Old Feb 6th, 13, 10:05 PM
Jeff
yellow69RS's Avatar
The grill has 4 holes for the nozzles in it. One to the right of each light, one to the left. They holes are kind of oval shaped if I recall correctly.
Jeff
post #14 of 17 (permalink) Old Feb 7th, 13, 12:01 AM
Tim
Here's the relevant pages of the 69 AIM:
ZLP955 is offline
post #15 of 17 (permalink) Old Feb 7th, 13, 05:39 AM
George
Papa's Avatar
Thanks guys ,
Tim where can I purchase these documents
Papa is offline
