poppin fuses - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 16th, 09, 08:25 PM Thread Starter
poppin fuses
wassup guy i have a 97 lt1 that started missing and completly quit on me a few months ago so i swaped opti (5th time) and checked coil/icm every thing checked out so i moved to fuses(i dont know why i work backwards) but my ignition fuse under the hood was blown i put a new fuse in and it ran fine for about 5 minutes then popped again went to a 15 and same thing someone told me the only components on the circuit was cps coil and module i cant work on it this very second due to the cold but im thinking the set of grounds that are on the coil arnt grounded good or the cps has shorted due to antifreeze thats been dumped on it. if anyones got any opinions or diagrams i could check out it would be greatly appriciated.thanks guys for all the help. ps anyone trying for ASE master tech. buy a lt1 camaro the ignition system must have been designed by a ford engineer.
coreylee051188 is offline
post #2 of 2 (permalink) Old Jan 17th, 09, 04:50 PM Thread Starter
Re: poppin fuses
also whe the car is only blows fuses when its warmed up the coilohmed to 9 on every pole and thats 5 min. after it cut off. ignition module checked out ok and my car hasnt been in closed loop in years so if that helps thanks guys.
