rs headlamps - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 22nd, 09, 06:07 PM Thread Starter
rs headlamps
hi, working on 67 rs headlamp cover motors all wiring seems to be there and headlamps open and come on but will not close unless you tip the doors with the key on. thinking maybe some kind of adjustment. car has been through complete frame off restoration and wiring looks practically new. also has new door motors. any help would be much appreciated. thanks
batteryjunky is offline
post #2 of 3 (permalink) Old Jan 22nd, 09, 07:16 PM
Roger
Re: rs headlamps
Here is a link that has troubleshooting the headlamp motors/assembly, go to the link then look at the wiring diagram for RS headlamp assembly...there are detailed instructions:http://www.gvtc.com/~rlaa/ good luck
Roger 67 RS/SS350
Roger344 is offline
post #3 of 3 (permalink) Old Jan 23rd, 09, 11:01 AM Thread Starter
Re: rs headlamps
found radiator mounted limiter switches were not grounding through paint. added internal lock washers and all is well
