Headlight Wiring Question - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 24th, 09, 07:17 PM Thread Starter
Eloy
I wanted to know if anybody knew how is it that i could wire up my headlights to turn off when i turn my car off. It is a 67 Camaro. Any help is very much appreciated.
Bowtie707 is offline
post #2 of 6 (permalink) Old Jan 24th, 09, 07:21 PM
Brandon
Re: Headlight Wiring Question
are you planning on keeping the light switch pulled out at the time as well.. If so, Run a wire from the ign terminal of the start switch to a relay. Have that relay control power to your light switch.
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 6 (permalink) Old Jan 24th, 09, 07:29 PM Thread Starter
Eloy
Ok then Thats Exactly What I Wanted To Know. So I Just Get The Wire Off The Direct Source and Add It To A Switch Source Right?
post #4 of 6 (permalink) Old Jan 24th, 09, 08:13 PM
Brandon
yes, esentually that's it. I suggested the relay though to keep from putting too much of a draw onto the ignition side so that power to the coil isn't interferred with.
Nantooch is offline
post #5 of 6 (permalink) Old Jan 24th, 09, 08:15 PM Thread Starter
Eloy
Ok Then Thanks Alot! Thats What I Needed To Know. I Appreciate Your Help
post #6 of 6 (permalink) Old Jan 26th, 09, 06:40 PM
Brandon
Ukiah, just noticed that. Home of Red Tail Ale.. good stuff!
Nantooch is offline
