Breakerless Elec Ign Conversion - Team Camaro Tech
post #1 of 9 (permalink) Old Jan 25th, 09, 11:19 PM Thread Starter
Charlie
Saw this on eBay, anybody used this or similar conversion system? Any thing better out there?
Here is the link: http://cgi.ebay.com/ebaymotors/ws/eB...%3AIT&viewitem=
cdaubs is offline
post #2 of 9 (permalink) Old Jan 26th, 09, 04:19 AM
Re: Breakerless Elec Ign Conversion
Conventional system develop only 24,000 volts when a car is running at 10 mph. But this voltage drops to 17,000 volts when the car reaches 100 mph. A detrimental 40% drop in voltage to fire the air/fuel mixture under high load conditions.
I like the numbers...40% of what?
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #3 of 9 (permalink) Old Jan 26th, 09, 04:40 AM
For that kind of money, you're so close to what Dave Ray charges to do his conversion (which uses easy to find parts in case something goes bad) I wouldn't even consider this kit. www.davessmallbodyHEIs.com . If you know your engine's specs, Dave will recurve it using his distributor machine, and it will be perfect.
If you want to do it yourself, the Pertronix or Crane kits are about half this price at Summit, and many folks here have used one or the other.
Eric
Eric Kammerer is offline
post #4 of 9 (permalink) Old Jan 26th, 09, 04:46 AM
I believe the seller means a 40% drop of secondary voltage, i.e., 24Kv to 17Kv.
I believe the coil is the limiting factor, the higher the frequency, the less time to build EMF.
post #5 of 9 (permalink) Old Jan 26th, 09, 05:14 AM
If you went into a dealership, looked at a $24,000 dollar car and the dealer offered to reduce the price by 40%, would you pay $17,000 for it? I'd only pay $14,400 if it was me.
post #6 of 9 (permalink) Old Jan 26th, 09, 09:24 AM Thread Starter
Charlie
Eric,
That sounds much better to me. Thank you!
cdaubs is offline
post #7 of 9 (permalink) Old Jan 26th, 09, 09:28 AM
You forgot to add Dealer Prep, titling, licensing, state tax, processing fee, and destination charge.
And yes, using over the counter parts is alot better than specific parts.
post #8 of 9 (permalink) Old Jan 26th, 09, 04:37 PM
Daniel
Hi cdaubs,
I have a Crane XR-i module in my car, its been installed for more than 5 years now without any problem.
The module works fine for me, the installation was quite simple.
The only issues was that I had to file the XR-i module Aluminum Heatsink a bit in order to clear a clamp (in the distributor) that interfered a bit with the module.
It was really easy to install, did it with the distrubutor still installed in the car, plus I didn't need to disassemble my distributor.
Good Luck, Daniel.
Daniel,
1969 SS-350 Camaro, Hugger Orange
2005 Black Mustang GT
FBODY is offline
post #9 of 9 (permalink) Old Jan 26th, 09, 06:47 PM
I tried two of those things, and the others, then, wised up, and now, I just send my distributors to Dave Ray. I get the conversion done right, the first time, no problems. Eric gave his contact info, ask about what he offers, it is the good stuff.
Regards,
Milton
The Devil's advocate is offline
