step on Brakes and console lights lite up - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 27th, 09, 10:42 AM Thread Starter
I haven't made any updates recently but this just started last week. I press down on the brake and the console and guage lights lite up. What ever it is causing my battery to go down also. Any suggestions on where to start trouble shooting?
thanks
bhollis is offline
post #2 of 5 (permalink) Old Jan 28th, 09, 05:54 AM
Guess
HwyStarJoe's Avatar
Re: step on Brakes and console lights lite up
Which year? The wiring is slightly different for each year depending on installed options, etc.
http://www.gvtc.com/~rlaa/
https://www.camaros.net/forums/showthread.php?t=93576
HwyStarJoe is offline
post #3 of 5 (permalink) Old Jan 28th, 09, 06:36 AM Thread Starter
Sorry - 69 z28
bhollis is offline
post #4 of 5 (permalink) Old Jan 28th, 09, 06:56 AM
Jeff
yellow69RS's Avatar
Have you changed any tail light bulbs lately? First thing into my head is feed back through the headlight switch on tail light circuit is lighting up the dash lights. That doesn't expalin the battery drain tho.
Jeff
yellow69RS is offline
post #5 of 5 (permalink) Old Jan 28th, 09, 07:43 AM
click's Avatar
Get your handy light stick out and put it between negative cable end (removed from battery) and the battery Neg post. If there is a draw (short) the stick lights up. Now start pulling fuses one at a time, when the light goes out you will know which circuit to start your trouble shooting on. It could be anywhere till you find the right circuit.
click is offline
