Smaller temperature sender for my 67 with console gauges? - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 29th, 09, 05:44 PM Thread Starter
Doug
Just wondering if anyone makes a 3/8 npt temperature sender for my car that will replace the 1/2 npt one? My car has the original console gauges. Thanks for the help.
Dougs72Nova is offline
post #2 of 6 (permalink) Old Jan 29th, 09, 06:07 PM
NHBandit's Avatar
Re: Smaller temperature sender for my 67 with console gauges?
One for a mid 80s Chevy car or pickup should be 3/8". Just order it for guages and it should work fine. I had to do that with my RHS heads since the holes were smaller than the early Chevy stock heads. Chrysler even uses one that's 1/4" NPT in the old K-cars & such with the 4 cylinder engines.
NHBandit is offline
post #3 of 6 (permalink) Old Jan 29th, 09, 06:40 PM
One for a '86-'88 Monte Carlo SS, I believe will work.
Standard Motor Products #TS76T
post #4 of 6 (permalink) Old Jan 29th, 09, 07:00 PM Thread Starter
Doug
Thanks guys.
post #5 of 6 (permalink) Old Jan 29th, 09, 09:18 PM
Measure the cold resistance of the one you have and before you give them your money for a sub, check it's resistance. They should be very close, if not the gauge won't read correctly.
dnult is offline
post #6 of 6 (permalink) Old Jan 30th, 09, 04:04 AM
Good point, Dnult. Either a TS76T or TS76. If it reads open, it will be a switch for a light.
If resistance is read, and like Dnult suggests, the new reading and original reading should be within a couple kohms. Both items should be at the same room temperature when reading.
When installing, make sure the body of the sending unit is grounded to the head to complete the circuit.
