rs headlight switch - Team Camaro Tech
post #1 of 23 (permalink) Old Feb 1st, 09, 02:07 PM Thread Starter
Lars
67 Sinner's Avatar
rs headlight switch
Hello, folks!
does anybody know if this wire goes to the headlightswitch?
It has one light-blue wire and one brown. It also has a grommit, so my guess is that is shall go trough the firewall somewhere..
Newbie from the North
'67 Camaro 350 / 350 (part RS-clone)
67 Sinner is offline
post #2 of 23 (permalink) Old Feb 1st, 09, 05:43 PM
Re: rs headlight switch
Originally Posted by 67 Sinner View Post
Hello, folks!
Lars - Yes, is should run through the firewall.The light blue comes from the headlight switch and the brown comes from the ignition switch. Both are used to control headlight door opening and closing.
On the interior side, you should have 12V on the light blue when the headlight switch is pulled fully out and 12V on the brown whenever the key is in the 'ON' position.
Melrose RS is offline
post #3 of 23 (permalink) Old Feb 1st, 09, 11:24 PM Thread Starter
Lars
67 Sinner's Avatar
ok.
But how does it connect?there isn't one connector for each wire, so it has to connect at the same place..
post #4 of 23 (permalink) Old Feb 2nd, 09, 09:24 AM
I think the end you are holding will pass through a hole in the firewall below the master cylinder. Then on the interior side you should find a similar connector that mates to it. This assumes your dash wiring is intact.
post #5 of 23 (permalink) Old Feb 3rd, 09, 06:52 AM Thread Starter
Lars
67 Sinner's Avatar
What is the trick to seperate the headlightswitch? I need to get the knob out, to release the entire thing, but I am too dumb to figure this out. I don't want to break anything either..
post #6 of 23 (permalink) Old Feb 3rd, 09, 08:15 AM
It's a little complicated. On the switch there is a spring-loaded push button. Hold it in and pull the knob and shaft of the switch out. You have to hold the push button in hard and jiggle the knob out. Then you can unscrew the bezel. I think I used a butter knife across the bezel. There is a special tool if you want to spent the money.
post #7 of 23 (permalink) Old Feb 3rd, 09, 09:58 AM
click's Avatar
here ya go this is my 69 unit but same spring loaded button is used. Slowly push it in, slowly pull out the shaft as you hold the pin 'in'.
click is offline
post #8 of 23 (permalink) Old Feb 4th, 09, 12:18 AM Thread Starter
Lars
67 Sinner's Avatar
aha!
Thanks guys!
post #9 of 23 (permalink) Old Feb 4th, 09, 02:56 PM Thread Starter
Lars
67 Sinner's Avatar
So, I need to pull the lightblue wire from the headlightswitch and the brown from the ignition, and then connect them to the blue and brown from the harness, right?
post #10 of 23 (permalink) Old Feb 4th, 09, 03:09 PM
"Pull" meaning disconnect? No, you should have a connector somewhere above your brake pedal with only a brown and light blue wire that mates to the one shown in your photo.
post #11 of 23 (permalink) Old Feb 4th, 09, 03:13 PM Thread Starter
Lars
67 Sinner's Avatar
yes, I ment disconnect..
Haven't seen that connector, but it's a pain in the a$$ to see anything under the dash. But I'll sure look for it!
Thanks Thomas
post #12 of 23 (permalink) Old Feb 4th, 09, 05:51 PM
Rick
Camaro67_rcl's Avatar
Send a message via Yahoo to Camaro67_rcl
drop the steering column fron the dash & pull dash cluster ,,, makes it easy to get to wiring & headlight switch
Rick
67 RS/SS 355, Autogear M21 (w/Overdrive), 8.5w/3.42
Camaro67_rcl is offline
post #13 of 23 (permalink) Old Feb 5th, 09, 03:45 AM Thread Starter
Lars
67 Sinner's Avatar
Is that connector in both rs and non-rs cars?
It might be me that just don't see this, but here it looks like the light blue and brown should be disconnected..
Name:	Wiring diagram switch w.r.b.jpg
post #14 of 23 (permalink) Old Feb 5th, 09, 04:11 AM
Nope, Schematics show connections "disconnected" for clarity and illustration purposes. If I am understanding your question correctly. And as Tom said. You should have a connector in the dash harness for the RS headlights, unless the harness is wrong.
Sauron67MM is offline
post #15 of 23 (permalink) Old Feb 5th, 09, 04:38 AM Thread Starter
Lars
67 Sinner's Avatar
So there's no difference in RS and non-RS wiring?
I thought that since my car is not an original RS, that I had to take a shortcut and do like the picture says..But I have been wrong before..
