69 RS headlight washers - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 9th, 09, 12:32 PM Thread Starter
Are the headlight washers wired together with the windsheild washers on the factory harness at the washer pumps? Are they both supposed to "wash" when you push the button inside the car or is there someway to turn one or the other on. My harness was quite a rat's nest in that particular spot and I'd like to make it right.
Lance-w is offline
post #2 of 9 (permalink) Old Feb 9th, 09, 03:51 PM
mark
mark x22's Avatar
Re: 69 RS headlight washers
it works by holding in the wiper switch .
you need
1969 Rally Sport (RS) Headlight Washer Pump Wiring Harness pn 97543 at ricks . then plug windshield wiper pump harness into it .
mark x22 is offline
post #3 of 9 (permalink) Old Feb 9th, 09, 05:22 PM
Fred
Yeah, shoot for something like this;
128.79mph 1.428 60'
Fred Ficarra is offline
post #4 of 9 (permalink) Old Feb 9th, 09, 06:43 PM Thread Starter
So it just gets jumpered off the "normal" washer pump? So there is no way to turn on just the headlight washers or just the windshield washers on individually?
Lance-w is offline
post #5 of 9 (permalink) Old Feb 9th, 09, 08:08 PM
mark
mark x22's Avatar
the solenoid puts fluid either to the windshield or the headlights one at a time it cant do both at once .
mark x22 is offline
post #6 of 9 (permalink) Old Feb 9th, 09, 10:04 PM Thread Starter
OK, got the hose routing. That part makes sense to me. The part I'm struggling with here is if both wires are run to the pump and then both wires are run to the solenoid how does the solenoid know to switch from the headlights to the windshield? You push the windshield wiper switch in to actuate the pump. Is there something else you do to tell it windshield or headlights? I'm obviously missing something here?
Lance-w is offline
post #7 of 9 (permalink) Old Feb 10th, 09, 03:52 AM
mark
mark x22's Avatar
you push in and hold the switch in for headlights , you push in and release for windshield .
mark x22 is offline
post #8 of 9 (permalink) Old Feb 10th, 09, 07:48 AM
click's Avatar
mark is right. when you first push the button 'in' it activates the washer pump to run its cycle on the windshield. If you hold the button 'in' and not let go, it also squirts the headlights at the same time. I dont think you can get the system to ONLY squirt the headlights.
click is offline
post #9 of 9 (permalink) Old Feb 10th, 09, 12:33 PM Thread Starter
Thanks Mark, That makes sense to me.
Lance-w is offline
