Battery Cable Wire - What Gauge? - Team Camaro Tech
post #1 of 13 (permalink) Old Mar 12th, 09, 04:50 PM Thread Starter
Lifetime Gold Member
Drew
ddx77's Avatar
Hey guys, what's the proper or the best gauge wire to use for battery cables and grounding cables.
Stock Location
________________________________
1st Genless again - Working on getting my 69Z28 back.
ddx77 is offline
post #2 of 13 (permalink) Old Mar 12th, 09, 05:03 PM
Rod
Re: Battery Cable Wire - What Gauge?
Is the battery located in the stock location, or in the trunk?
Rod
69 Camaro with LS2/4l70e
Rocketrod is offline
post #3 of 13 (permalink) Old Mar 12th, 09, 05:10 PM Thread Starter
Drew
ddx77's Avatar
stock location
ddx77 is offline
post #4 of 13 (permalink) Old Mar 12th, 09, 05:11 PM
Minimum #1 AWG
post #5 of 13 (permalink) Old Mar 12th, 09, 05:23 PM
Larry
larryh56's Avatar
IMO if you have an original car (no new electric goodies) #2 is fine.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #6 of 13 (permalink) Old Mar 12th, 09, 05:28 PM Thread Starter
Drew
ddx77's Avatar
Not really an original car (I wish) and what I am trying to do is run my cables so they are a bit more hidden.
ddx77 is offline
post #7 of 13 (permalink) Old Mar 13th, 09, 10:41 PM
Steiner
I've got 1/0 from my battery to the starter, alternator, and grounds. When connecting to the stock harness, it won't do much good to go big since the stock cable is what, 8-10AWG? Well, at least on my '69. I'm going to redo that eventually....
Steiner is offline
post #8 of 13 (permalink) Old Mar 14th, 09, 01:07 PM
A bigger cable isn't for running accesories, it's for carring cranking amps to the starter.
Oldrocker is offline
post #9 of 13 (permalink) Old Mar 14th, 09, 02:27 PM
Steiner
That depends on what the amperage draw is of the accessories.
Steiner is offline
post #10 of 13 (permalink) Old Mar 14th, 09, 04:00 PM
You mentioned going to the stock harness. There are no accessories that connect to the stock harness that draw enough amps to require a large cable, and nothing that requires a large amount of amps should be connected to the stock harness. If you are speaking of aftermarket accessories like stereo amplifiers etc... then a separate cable large enough to carry the required amps should be connected directly to the power source or a junction block designed to handle a large amount of amperage.
post #11 of 13 (permalink) Old Mar 14th, 09, 04:08 PM
On the nail, Steiner.
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
captcanuck68 is offline
post #12 of 13 (permalink) Old Mar 14th, 09, 04:13 PM
Steiner
Yes. And my original post that you quoted stated this:
"When connecting to the stock harness, it won't do much good to go big since the stock cable is what, 8-10AWG?"
As in, connecting a bigger cable to the stock harness won't do any good because you'd have say a 4AWG cable connected to an 8AWG cable. I was talking about connecting to the stock harness right off the battery if there was any confusion, not the starter harness or alternator harness. As I said, both of those are already 1/0 in my case. I upgraded the alternator line to battery in case I wanted to add more accessories later and had to upgrade my bus line.
Steiner is offline
post #13 of 13 (permalink) Old Mar 14th, 09, 07:26 PM
I understand your point and it is valid. My point when used in the original context is also valid. If using a factory harness the only good reason to run a bigger cable is to provide more available cranking amps to the starter. So in reality we are both right but looked at the question in different directions.
