Under hood wiring problem - Team Camaro Tech
post #1 of 12 (permalink) Old Mar 13th, 09, 04:02 PM Thread Starter
Unhappy Under hood wiring problem
Been a member for awhile but never had a question 'till now. I am reassembling my '68 RS with original 327 build to Corvette specs. I fired it up for the first time this week and it sounds awsome. The problem I have is in the wiring. I get a a little smoke from the voltage regulator and my wiper motor gets really hot when the key is on. I've double checked and tripple checked the grounds etc. This really has me stumped. Any electrical wizards out there? Help.
pollworth is offline
post #2 of 12 (permalink) Old Mar 13th, 09, 04:04 PM
Brandon
Re: Under hood wiring problem
What was done with the electrical?
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 12 (permalink) Old Mar 13th, 09, 04:12 PM Thread Starter
The electrical is original but has been inspected and repaired where necessary. No broken, cracked, or poor wires or terminals.
post #4 of 12 (permalink) Old Mar 13th, 09, 04:19 PM
You have a hot lead hooked to ground somewhere.
Musclerodz is offline
post #5 of 12 (permalink) Old Mar 13th, 09, 04:23 PM
Banned
Ron
Badbird's Avatar
Perhaps the points are stuck, in the voltage regulator!
I have a freshly rebuilt 1967 327 built to L-79 specs!.....I get a head rush every time I fire that thing up!....I don't know the specs of the cam but it sure blows my mind!
Badbird is offline
post #6 of 12 (permalink) Old Mar 13th, 09, 04:26 PM Thread Starter
Could be it . . . I'll do a check on the positive routings. Thanks, that gives me something to go on.
post #7 of 12 (permalink) Old Mar 13th, 09, 04:30 PM Thread Starter
Thanks, I've already checked the points, Not the problem. Your cars sounds great. They should have offered the L79 option in the Camaros just like they did in the Novas and Chevelles. Mine has date coded 202 heads, 9.5 to 1 compression, and looks like a factory engine.
post #8 of 12 (permalink) Old Mar 13th, 09, 07:22 PM
I'd check the alt case for a hot case meaning alt is being told to output max amps due to a stuck relay in the regulator. If so, I'd swap out the mechanical reg for an electronic one, Wells P/n VR715.
post #9 of 12 (permalink) Old Mar 13th, 09, 08:01 PM
If I had a color coded wiring schematic for the engine harness I would post it for you. Sometime problems like yours can be a real bear trying to assist with diagnosing without a schematic to referrence.
deerhunter is offline
post #10 of 12 (permalink) Old Mar 14th, 09, 08:51 AM
Gary
I put an electronic regulator in my car (bought at Auto Zone) and used an original Delco Remy cover. Best of both worlds.....modern electronics with factory look. Only the most discerning can tell the difference.
Unreal is offline
post #11 of 12 (permalink) Old Mar 14th, 09, 09:39 AM
Wiper motor should not be hot if off. Unplug it and see what else happens.
post #12 of 12 (permalink) Old Mar 14th, 09, 10:07 AM
Kevin
There's a Team Camaro member that offers a color diagram real cheap. I would do a search in the electrial forum Kevin
kcart55 is offline
