69 Camaro ground straps - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 16th, 09, 06:27 PM Thread Starter
Rob
Anybody give me locations for ground straps under hood on a 69 camaro-327 engine?
RobMc is offline
post #2 of 8 (permalink) Old Mar 17th, 09, 09:37 AM
Steiner
Re: 69 Camaro ground straps
I ran 1/0 from the battery negative to the alternator bracket frame and another from an unused accessory hole on the driver's side head to the cross brace mount at the fender, but the frame is also a good place. It should be getting a ground through the motor mount already though. There is also a small one going to the brace right behind the battery that was already there that I maintained.
If I ever get around to installing a stereo, I'll have to see if I have any problem with ground loops but I'm trying to get everything grounded out to the same potential.
Clean all the mount points of paint and gunk and use a good dollop of dielectric grease.
Steiner is offline
post #3 of 8 (permalink) Old Mar 17th, 09, 10:26 AM
DjD
DjD's Avatar
I think Rob is asking about the noise suppression ground straps for the radio...
This should help Rob;
https://www.camaros.net/forums/showth...=ground+straps
...Dennis
DjD is offline
post #4 of 8 (permalink) Old Mar 17th, 09, 10:36 AM
Steiner
I thought he meant these for chassis and body grounding. Sorry.
Steiner is offline
post #5 of 8 (permalink) Old Mar 17th, 09, 10:50 AM
DjD
DjD's Avatar
All those straps are part of a radio option... The only grounding a Camaro got from the factory to allow it to run is the ground cable from the battery's neg post to the block and the small strap from the battery's neg post to the inner fender.
...Dennis
DjD is offline
post #6 of 8 (permalink) Old Mar 17th, 09, 01:15 PM
Den
DenRS's Avatar
My 69 has one ground strap running from the inner fender passenger side to the frame. Its in front of the tire. I have two straps going from the valve cover bolts to the firewall. The drivers side strap goes on the outside of the valve cover bolt above the header while the pass side goes to the inside valve cover bolt next to the manifold. My 4th strap is on the frame below the heater box. Mine is broken, but I think it attaches to the one of the screws for the heater box.
DenRS is offline
post #7 of 8 (permalink) Old Mar 17th, 09, 02:00 PM
Fred
x2 for my BBC. (sorta)
128.79mph 1.428 60'
Fred Ficarra is offline
post #8 of 8 (permalink) Old Mar 17th, 09, 06:29 PM Thread Starter
Rob
Thanks for the help
RobMc is offline
