'69 Camaro tacho problems - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 17th, 09, 05:46 AM Thread Starter
Just finishing wiring up my '69 Camaro & it's fitted with a factory tachometer. All of the wiring is as it should be, but when the ignition is turned on, the tacho bumps up to 1000 revs & stays there. There's no coil on it at the moment, but I'm fitting an MSD6AL to it. Is there anything else that needs to be wired in to make the MSD compatible with the factory tach & why does it jump to 1000rpm with the ignition turned on, thanks........Nigel
evilzee28 is offline
post #2 of 4 (permalink) Old Mar 17th, 09, 06:55 AM
mark
Re: '69 Camaro tacho problems
I have a 6al and 5" tach and it does the same thing. I asked about that 2 years ago and got the same reply.
sick67 is offline
post #3 of 4 (permalink) Old Mar 17th, 09, 08:50 AM
Ted
Check out the other post fyi oer tach. And check the sticky in the elec. basics that Jim has.
tgifford5 is offline
post #4 of 4 (permalink) Old Mar 18th, 09, 09:52 AM Thread Starter
There isn't a coil or MSD connected yet, it jumps to 1000rpm just by turning the ignition key on, but it does return to zero once the key's turned off. Do stock GM tachs work on pulses from the coil? When fitting an MSD6AL can you just wire up to the tacho output on the MSD? thanks......Nige
