Reverse Light hole in firewall - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 17th, 09, 08:10 PM Thread Starter
I have a 68 that was originally an automatic, but now has a muncie 4 speed.
I have the engine out and would like to drill the hole in the firewall for the reverse light plug/connector. I don't know the exact location to drill the hole, and was hoping someone could send me a picture of the connectors location.
cox68 is offline
post #2 of 10 (permalink) Old Mar 17th, 09, 08:31 PM
Re: Reverse Light hole in firewall
See if the pics in this thread help: https://www.camaros.net/forums/showth...highlight=plug
Eric
Eric Kammerer is offline
post #3 of 10 (permalink) Old Mar 17th, 09, 08:38 PM
I just check my 68 AIM, and it shows the hole in the same place. If you have an AIM, the hole is shown on UPC 0 sheet A 8.5 (up front, 10 pages in or so). That is location 3C for RPO M20, and the AIM says to drill a .920/.940 diameter hole at existing dimple. So, if you can find the dimple, you just need a 15/16" drill bit (or more likely hole saw).
Eric
post #4 of 10 (permalink) Old Mar 17th, 09, 09:38 PM
Dale
This will help, along with the others
dale
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
post #5 of 10 (permalink) Old Mar 18th, 09, 08:55 PM Thread Starter
Thanks for the help I got it installed tonight.
cox68 is offline
post #6 of 10 (permalink) Old Mar 19th, 09, 09:45 AM
Armando
tejasrs/ss's Avatar
dale
so which one is the ACTUAL hole??
Armando
1967 Chevy Camaro RS/SS
2012 Ford F150 Supercrew FX4
2007 Ford Mustang GT/CS (sold)
2002 F150 Harley Davidson (sold)
tejasrs/ss is offline
post #7 of 10 (permalink) Old Mar 19th, 09, 10:45 AM
Kevin
sleepsinshed's Avatar
It's the one above and to the right of the throttle rod hole.
Kevin
sleepsinshed is offline
post #8 of 10 (permalink) Old Mar 19th, 09, 10:56 AM
Bill
Holesaw works, but I like to use a step drill bit for holes in thin metal
Bill
1969 Red SS
496 570 Hp
Tko 600 with 4:10
bcvet is offline
post #9 of 10 (permalink) Old Mar 19th, 09, 12:52 PM
Armando
tejasrs/ss's Avatar
Thanks!
Armando
post #10 of 10 (permalink) Old Mar 19th, 09, 04:05 PM Thread Starter
I did use a step drill bit and it worked good. I was able to go up one step at a time and check the fit after each step, until I got it perfect.
There was/is a dimple in the firewall where the hole should be.
Thanks again for the help.
cox68 is offline
