power retractable antenna - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 18th, 09, 02:03 PM Thread Starter
Can they be used on front mount?
bnbpaintballer is offline
post #2 of 9 (permalink) Old Mar 18th, 09, 04:16 PM
Re: power retractable antenna
I dont see why not
Larry B is offline
post #3 of 9 (permalink) Old Mar 18th, 09, 04:22 PM
You may find an aftermarket one that fits also.
68 Camaro~LSx ~all motor
post #4 of 9 (permalink) Old Mar 18th, 09, 07:48 PM
Let us know if you find one that fits. There's not much room under there.
go2fast is offline
post #5 of 9 (permalink) Old Mar 19th, 09, 11:37 AM Thread Starter
I will see what I can come up with.
post #6 of 9 (permalink) Old May 22nd, 09, 04:21 PM
Todd
6781camaro's Avatar
I found out that in the 69 Firebirds and TA's, that the power antennas were available as a factory option, BUT they were all rear 1/4 mounted instead. If you can clear the inner fender well underneath the surface of the front fender, I don't see a problem with having a front-mounted pwr antenna too. I went with a rear 1/4 mounted powered one from a 60's Cadillac though. They are bulletproof and clean up really nicely.
'69 Frst Grn V8 Cpe-Building now!
'68 Sequoia Grn V8 Cpe--Building now!(too),
'67 White 6 Cyl Coupe Building now (three!)
'68 Conv. V8 4-spd Builder, '68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD
My build thread:
6781camaro is offline
post #7 of 9 (permalink) Old May 22nd, 09, 07:48 PM
Steiner
I put in an APC power antenna on the right rear quarter using a 15ft. extension. Works great. $75 on Summit. Ebay: TWENNY NINE DOLLA
'69 Camaro
500hp/538lbft
Steiner is offline
post #8 of 9 (permalink) Old May 26th, 09, 09:29 AM
Steiner,
Was the factory hole in the rear quarter a perfect fit for the APC antenna?
67 3L 4P Project Car
I just had to have some wings.
67 RS/SS Pictures
cpodeep is offline
post #9 of 9 (permalink) Old May 26th, 09, 10:44 AM
Steiner
Originally Posted by cpodeep View Post
Steiner,
I had to drill a hole. Mine was probably originally a front mount but the front fenders were replaced some time before I got it in '93 and there is no hole in either.
It takes a 16mm hole which is a little larger than 5/8".
'69 Camaro
500hp/538lbft
Steiner is offline
