distributor, coil wiring - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 19th, 09, 07:12 PM Thread Starter
I need a diagram showing the wiring to and from the distributor and coil. Thanks
68fan is offline
post #2 of 7 (permalink) Old Mar 19th, 09, 08:53 PM
Re: distributor, coil wiring
If a '68, then you need the cloth covered white wire to + coil along with yellow wire from starter solenoid. The white wire would be ignition feed.
Then need black pigtail from distributor to - coil, along with green wire from tach, if equipped.
post #3 of 7 (permalink) Old Mar 20th, 09, 06:57 AM
click's Avatar
Ken pick up the 68 AIM, it has full electrical diagrams in it. Assembly Instruction Manual, most repo parts dealers have them, so does Ebay.
click is offline
post #4 of 7 (permalink) Old Mar 20th, 09, 10:22 PM Thread Starter
I can't get it to fire. I followed the diagram. Help>
68fan is offline
post #5 of 7 (permalink) Old Mar 21st, 09, 08:33 AM
Dale
Are you missing spark? If so.
Do you have power to the + side of the coil with key turned on?
Are the points good, and adjusted properly.
Dale
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
post #6 of 7 (permalink) Old Mar 21st, 09, 09:56 AM
Diagrams are on Geezer's site: http://www.gvtc.com/~rlaa/
Eric
Eric Kammerer is offline
post #7 of 7 (permalink) Old Mar 21st, 09, 02:48 PM
Following the diagram won't make it fire. Following the diagram helps you figure out things like "do I have power at the ignition coil?" or "Do I have sufficient battery voltage to generate a spark?". If you tell us what you found, we can help you find what you haven't found. If we all sit around and guess you'll wind up paying money for parts you don't need.
dnult is offline
