Mechanical vs Electric gauges - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 21st, 09, 08:54 AM Thread Starter
Rick
Starting to look at gauges. I am looking at the Auto Meter gauges, Ultra Lite II or the Phantom II. I love the night/day switch
Plans: In dash Tach and speedometer (5 inch for 68 camaro correct?)
Converting my automatic console into a manual transmission console (possible?) with the 4 gauge (2 1/16) Water temp, volt, oil pressure and fuel level guages.
What is the difference between mech and elec gauges? Difference in setup? Difficulty in set up?
Also will be using American Autowire Classic update kit for my 68. Will I need to by the Autometer harness for the console gauges? Any issues with the speedometer and tach connections
TKO being installed, MSD ignition (site says no issues with Autometer Tachs.)
Rick
dukemd66 is offline
post #2 of 6 (permalink) Old Mar 21st, 09, 10:07 PM
Skip
Skeeter55's Avatar
Re: Mechanical vs Electric gauges
Good question.... I'm watching this thread as well because i have both and don't know which is the better out of the two.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 6 (permalink) Old Mar 21st, 09, 10:15 PM
Todd
Electrical all the way. The TKO has a speed sensor and you can calibrate your speedo dead on in 5 minutes. Who wants oil in your passenger compartment if not needed? The MSD box works perfect with the autometer gauges.
Vegas69 is offline
post #4 of 6 (permalink) Old Mar 22nd, 09, 06:53 AM
Ed
BigBlock1969RS's Avatar
The nice thing with Mechanical temp gauges at least is you can still get a reading off of them even with the key off.
Ed
BigBlock1969RS is offline
post #5 of 6 (permalink) Old Mar 22nd, 09, 07:18 AM
I actually prefer mechanical gauges, they have a much longer sweep and are easier to read. Plus you dont need a big sending unit hanging off the motor to power the gauge. If you use a mechanical oil pressure gauge, you should install a copper line, instead of the supplied nylon one, for safety; most competitive organizations require that.
rlovell383 is offline
post #6 of 6 (permalink) Old Mar 22nd, 09, 10:12 AM
Randy raises a good point about mechanical gauges. They tend to have a longer sweep. However, there are mechanical gauges that are long-sweep types.
In terms of accuracy, I don't think you could conclude that mechanical is more or less accurate than electrical gauges are. Some electrical gauges have a calibration pot located inside the bulb socket on the back.
IMHO, electrical gauges are hard to beat in terms of hookup and reliability. I've experienced the bedredded leaking oil line to the oil pressure gauge. Mechanical temp gauges have that knarly flexible line that you have to fish through the firewall and secure without a kink. Electrical gauges solve a lot of those headaches, though full sweep gauges would be nice to have.
dnult is offline
