67 Voltage Regulator Location?? HELP!! - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 24th, 09, 08:53 AM Thread Starter
Question 67 Voltage Regulator Location?? HELP!!
Hello Guy's,
I ran into a issue wiring the the headlights on my 67, I have a aftermarket core support and it does not seem to have the Voltage regulator mounting holes, No matter how I position it nothing seams to line up with the 3 holes in the regulator or let's it lay flat, I have the Factory assembly manual which shows it above the horn relay and angled with the wire connection toward the fender.
WOULD ANYONE HAVE A PHOTO OF THERE"S IN THE STOCK LOCATION??
PLEASE HELP!!
67 427 Camaro, /85 Elcamino
Ricks427 is offline
post #2 of 6 (permalink) Old Mar 24th, 09, 10:24 AM
Re: 67 Voltage Regulator Location?? HELP!!
Correct location is above the horn relay. You might have to drill holes to secure it.
post #3 of 6 (permalink) Old Mar 24th, 09, 10:27 AM
mark
Not sure if your trying to put everything to stock locations but I made a bracket and mounted my horn relay and voltage regulator inside the fender then made covers that mount to the inner fender, fender, and radiator support and it looks real clean. I also ran the wires to the fuse box between the fender and inner fender. I think wires look like crap so I go through alot to try to hide them
sick67 is offline
post #4 of 6 (permalink) Old Mar 24th, 09, 12:04 PM
jim
I had the same problem, I just drilled my own holes, not sure if its exactly stock.
67forever is offline
post #5 of 6 (permalink) Old Mar 25th, 09, 07:40 AM Thread Starter
Wink Re: 67 Voltage Regulator Location?? HELP!!
Thanks Guys for the feedback! I'm trying to put it back in the stock location, I don't mind drilling a few holes if I know it correct.
Any Photos out there on a Stock Core Support??
Ricks427 is offline
post #6 of 6 (permalink) Old Mar 25th, 09, 08:13 AM
Rick
Camaro67_rcl's Avatar
Send a message via Yahoo to Camaro67_rcl
I have the electronic version but it replaced an original.
Hope these help. More if need.
ID:	9672   Click image for larger version
ID:	9673   Click image for larger version
Rick
67 RS/SS 355, Autogear M21 (w/Overdrive), 8.5w/3.42
Camaro67_rcl is offline
