cowl induction wiring - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 25th, 09, 12:39 PM Thread Starter
Question cowl induction wiring
I am in the process of trying to get my cowl induction on my 69 camaro back in working order. Problem is I do NOT know where to connect the two (2) wires at the fuse block? Lost the instructions in the house move.
Does it make a difference which of the electric connections go where at the fuse block?
tazmanfire is offline
post #2 of 3 (permalink) Old Mar 26th, 09, 07:49 PM
Larry
Re: cowl induction wiring
It really wouldn't matter how the wires are connected as they both need to be powered for the setup to work. That only occurs when the key is in the RUN postition. In the ACC position, only one wire would be powered. (Although I think the connectors will only allow them to be inserted in their respective locations).
To be factory correct, the pink wire goes to the IGN terminal and the tan wire goes to the ACC terminal.
69-er is offline
post #3 of 3 (permalink) Old Mar 27th, 09, 07:12 AM Thread Starter
Thanks for the help. I tried it and got things working.
