posi battery connect starter spins - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 25th, 09, 01:33 PM Thread Starter
Just put a new starter on and when i connect the positive battery cable, it arcs and the starter engages....crossed wires at solenoid?
peteys68 is offline
post #2 of 3 (permalink) Old Mar 25th, 09, 01:53 PM
Vintage 68's Avatar
Re: posi battery connect starter spins
Power is getting to the "S" terminal on the starter solenoid...
Recheck to see if you twisted the bat. wire connector around to touch it or if there is power being applied there from other source.
If the Bendix drive is partially extended (stuck out) it can also run the starter motor.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 3 (permalink) Old Mar 25th, 09, 03:12 PM Thread Starter
WOW, 1 reply...problem solvedthis place rocks. THANKS, JOHN
peteys68 is offline
