69 engine harness wiring help please. - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 26th, 09, 04:54 PM Thread Starter
Skip
Skeeter55's Avatar
Hi everyone and thanks in advance,
I have removed my MSD ignition/box and i am replacing the MSD distributor with another Electronic distributor and coil... My question is i replaced all the wiring with the stock Engine Harness and wanted to see if and what wires to the coil and solenoid don't get used, i believe its the yellow to the solenoid but not sure of the coil wires.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #2 of 10 (permalink) Old Mar 26th, 09, 05:09 PM
Re: 69 engine harness wiring help please.
I've got an MSD Ignition......yellow and white resistance wire disconnected from + side of coil. Are you replacing/removing the MSD Ignition???
David F.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #3 of 10 (permalink) Old Mar 26th, 09, 05:29 PM Thread Starter
Skip
Skeeter55's Avatar
David F.
Yes im removing the MSD ignition and the brown wire to the - side coil and the yellow/white goes to the + side and my Auto meter tack does that go to the - side of the coil..
I'm sorry David i cant think straight.
post #4 of 10 (permalink) Old Mar 26th, 09, 05:42 PM
So discounect the y/w wires from the coil and starter solenoid yellow. Yes im removing the MSD ignition and the brown wire to the - side coil what goes to the + side and my Auto meter tack does that go to the + side of the coil..
Those wires are disconnected when using the MSD Ignition, if you are removing it, you'll need to reconnect them. Green wire on Auto Meter Tach goes to - on coil.
David F.
Turbo 400
post #5 of 10 (permalink) Old Mar 26th, 09, 05:46 PM Thread Starter
Skip
Skeeter55's Avatar
Those wires are disconnected when using the MSD Ignition, if you are removing it, you'll need to reconnect them. Green wire on Auto Meter Tack goes to - on coil.
David F.
OK i got it i think... Use all stock wiring on coil and solenoid plus the tack goes to the negative on the coil... Is this right.
post #6 of 10 (permalink) Old Mar 26th, 09, 05:48 PM Thread Starter
Skip
Skeeter55's Avatar
Thank you David, i should have my new dizzy tomorrow and today i installed all new OEM wiring harness.
post #7 of 10 (permalink) Old Mar 26th, 09, 05:49 PM
.The wire from the tach the was plugged into the MSD ignition now will be plugged into the - side of the coil.
David F.
Turbo 400
post #8 of 10 (permalink) Old Mar 26th, 09, 05:51 PM Thread Starter
Skip
Skeeter55's Avatar
David F.
Your the man...
post #9 of 10 (permalink) Old Mar 26th, 09, 06:03 PM
Your the man...
David F.
Turbo 400
post #10 of 10 (permalink) Old Mar 27th, 09, 07:55 AM
With an electronic distributor of any kind, you don't need the yellow wire from the starter terminal to the coil. In the OE application, it provided full 12V to the coil during starter engagement (cranking), then it would be de-energized and the coil was fed less than 12V though the resistance wire from the bulkhead connector, to keep the points from burning up prematurely. As long as you have a nice, thick (12 gage or so) feed wire (non-resistance) from the bulkhead connector to the coil positive, that's all you need.
Eric
Eric Kammerer is offline
