Powermaster Alternator Question - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 28th, 09, 04:32 PM Thread Starter
Clint
I bought a Powermaster alternator from Summit that is 1 wire or 3 wire hookup. Is there something special that you need to do to make it a 3 wire hookup? The instructions do not clearly state how to do this. I'm trying to hook this up with the AAW calssic update kit for my 69.
Thanks,
Clint
cwb90 is offline
post #2 of 6 (permalink) Old Mar 28th, 09, 05:58 PM
Robert
Re: Powermaster Alternator Question
If your wire harness is set up for a three wire all you have to do is pop off the black cap covering the terminals on the altenater for the plug. Also I had to clock the alternater for my wire to reach the terminals.
There are no problems only solutions
68 Camaro, RS/SS, ZZ502, Retrotek Fuel Injection, 4 Speed.
2010 RS/2SS Black, 6 speed trans
68Holdon is offline
post #3 of 6 (permalink) Old Mar 28th, 09, 06:19 PM Thread Starter
Clint
Rob,
Thanks for the reply. I have the AAW Classic Update kit and I followed the wiring diagram. It shows a red wire coming off the battery terminal on the alternator to the terminal under the black cap and a brown next to it that goes to the alternator warning light. Does this sound right?
Clint
cwb90 is offline
post #4 of 6 (permalink) Old Mar 29th, 09, 06:41 AM
Robert
Clint,
My aaw harness had the plug built in to it, so all i had to do was plug it in to the alternater. I would call the guys at AAW and just confirm what you did with the wiring. They are great guys there and will answer all your questions.
68Holdon is offline
post #5 of 6 (permalink) Old Apr 1st, 09, 12:10 PM Thread Starter
Clint
Well I figured out my problem. After calling AAW and Powermaster, it seems like I got a alternator with a internal regulator that was jumpered across the spade terminals which prevented me from hooking it up as a 3 wire system. They were confused on how this could of happened but were very helpful. I exchanged the alternator today at Summit for the same part# and this one did not have the jumper. Below is a picture of what the old one looked like.
cwb90 is offline
post #6 of 6 (permalink) Old Apr 2nd, 09, 10:22 AM
The one in the picture is meant to be a 1 wire only.
stellar is offline
