1967 Gas gauge - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 5th, 09, 06:17 PM Thread Starter
607
1967 Gas gauge
I did a search n this forum but have no answer. I took out my dash gauge cluster (MPH/Gas). Took it apart, cleaned it up. i did pop the needle off the gas gauge but no issue. I put it back together and the gauge is beyond empty. I pluged it in, I do not recall any wires going to the gas side just the two screw studs with the plastic circuit board thing.
i am not real good at this stuff. Basically tried to put back exactyl as i found it. Is there a ground i am missing? Any tips.
607 is offline
post #2 of 3 (permalink) Old Apr 6th, 09, 06:15 AM
wade
Re: 1967 Gas gauge
your gas gauge is the brown wire in the main plug. the plug has numbers on it and the gas gauge wire is #1 . it is grounded through the thick "cable" and is grounded with you screw the whole dash back in. hope this helps
lownslowtexaco is offline
post #3 of 3 (permalink) Old Apr 6th, 09, 08:54 PM
SCOTT
Re: 1967 Gas gauge
One way to check from the tank to the gauge is, in the trunk, find the wire that goes to the sending unit and ground it. If your gauge moves you know you are good from the trunk forward.
OL SCHOOL is offline
