HELP...No power on any circuit..... - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 5th, 09, 07:07 PM Thread Starter
I started my 67 Camaro today and was backing it out of the garage. The engine died (cold) and when I went to restart it.....nothing happened.......the horn, lights...nothing is working.
The only thing I have done recently is by-pass the neutral safety switch (it is bad) but connecting the wires together which went to the switch....but it has started ok since then..
I checked out the car....the battery is fine...
Pos wire from battery to the solenoid is tight....
The starter will engage if I jump it with a screwdriver....
Still no lights or anything....electrical is not my strong suit.........any ideas?
Did I blow a fuse or something....?
johnm is offline
post #2 of 5 (permalink) Old Apr 5th, 09, 08:35 PM
Re: HELP...No power on any circuit.....
Check two places - the junction block next to the battery and horn relay buss bar.
Dsiconnect ground cable and remove the red wires from these places and wire brush everything and reassemble.
post #3 of 5 (permalink) Old Apr 6th, 09, 12:08 PM
Got fuse links on the starter? Check em
stellar is offline
post #4 of 5 (permalink) Old Apr 6th, 09, 12:13 PM
Not on a 67, they are at the horn relay
john68 is offline
post #5 of 5 (permalink) Old Apr 6th, 09, 12:34 PM
thanks
stellar is offline
