Oil light on - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 6th, 09, 01:40 PM Thread Starter
Keith
Oil light on
I had my 69 idleing while checking for a vac leak and walked around the bad and noticed the oil light was on. I cut it off and checked the oil and it was full. The engine sounded normal before I cut it off so I cranked it back up and the light stayed on again. So if a sending unit goes bad would it light up all the time or not at all? Or possibly either way?
z10kl is offline
post #2 of 8 (permalink) Old Apr 6th, 09, 02:36 PM
Chuck
chuck69ss's Avatar
Re: Oil light on
Could be sending unit. Could be that the pump is losing pressure which would be really bad. If you're getting oil up to your rockers, it's likely the sending unit.
Chuck B
RI
- Frost Grn, x11, 350 4bbl, COMPCam XE256H, Crane XR-i HEI, M20, posi, Flowmaster 2.5";
You can live in your car, but you can't drive your house.
chuck69ss is offline
post #3 of 8 (permalink) Old Apr 6th, 09, 03:30 PM
Re: Oil light on
first thing i would do is put in an oil pressure gauge.by the time that light comes on,the damage is already done.that is assuming the sender is ok.
hallysport is offline
post #4 of 8 (permalink) Old Apr 6th, 09, 05:00 PM Thread Starter
Keith
Unhappy Re: Oil light on
I bought a sending unit but didn't have a socket to change it. I cranked it and the light came on. When I rev it the light goes out but comes back on when the Rpms fall. That doesn't sound like a sending unit to me. But I would think it would be clacking or makeing some kind of different sound. This stock L48 350 has about 40k miles on it over the last 20 years since it was rebuilt.
z10kl is offline
post #5 of 8 (permalink) Old Apr 6th, 09, 07:02 PM
Re: Oil light on
Take the sender out and put an ohm meter between the terminal and the body. It should read nearly zero ohms. Then apply pressure to the port with regulated air pressure. Start at a low pressure and have a helper turn up the regulator while you monitor the meter. When the ohm meter reads O.L. or high resistance, you'll know what pressure the sender is tripping at.
Beyond this, you need an oil pressure gauge to test it before you risk damaging the motor.
dnult is offline
post #6 of 8 (permalink) Old Apr 6th, 09, 09:47 PM
Send a message via AIM to RamAirDave
Re: Oil light on
Testing with a mech op gauge is what I would suggest.
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #7 of 8 (permalink) Old Apr 9th, 09, 07:37 PM Thread Starter
Keith
Re: Oil light on
Sending unit was bad. Thanks guys
z10kl is offline
post #8 of 8 (permalink) Old Apr 9th, 09, 07:44 PM
Re: Oil light on
Good to hear
