Neutral safety switch - Team Camaro Tech
post #1 of 14 (permalink) Old Apr 11th, 09, 08:41 AM Thread Starter
Ulf
I don't have one installed. That means I don't have back up lamps working either. You guys know which type fits in my car? See picture:
I have some wires that confuse me. I thought the violet and violet/white wires are the ones for the back up lights? The previous owner have connected them together, I don't understand why.
I also have two "open" wires, are these for the safety part of the switch?
Omaniac is offline
post #2 of 14 (permalink) Old Apr 11th, 09, 08:45 AM Thread Starter
Ulf
Re: Neutral safety switch
Is this the switch I'm looking for? It's a TH 350 tranny.
http://www.drclassic.com/catalog/Cam...al/E00053.html
Omaniac is offline
post #3 of 14 (permalink) Old Apr 11th, 09, 09:07 AM
The violet and violet white wires are the neutral safety swith, that's why they are connected together. (car won't start if they are not!)
That link is the correct switch for a 67 though I have no idea how it attaches.
It looks like maybe the matching connector has been hacked off your car?
The other 2 wires must be the backup light, tho I'm used to pink for power and green for the light on a 68.
post #4 of 14 (permalink) Old Apr 11th, 09, 09:07 AM
geneo
67? yes the switch you post is correct. The violet and violet/white wires (purple) are the 'start' circuit, the other wires are for your backup lights. Since your wiring at the switch is cut, might consider a new console wiring harness.
Guess I need to learn to type faster....
gene_sc is offline
post #5 of 14 (permalink) Old Apr 11th, 09, 09:26 AM Thread Starter
Ulf
That explains the violet ones.
How do I test the other two? As I understand it, the wires from the back up lamps are connected together (one wire in the bundle) and the other one is 12 Volts for the power. Then I should be able to just put the two together and the lights should come on?
The switch attaches with two screws, you can see the holes in the first picture.
Omaniac is offline
post #6 of 14 (permalink) Old Apr 11th, 09, 09:39 AM
geneo
Yes, connecting the other 2 wires should make the backup lights come on.
gene_sc is offline
post #7 of 14 (permalink) Old Apr 11th, 09, 10:07 AM
Matt
Been there with my 68..Check out this thread. Good info and pics I put up that should help you.
https://www.camaros.net/forums/showthread.php?t=148995
Matt
zlek131 is offline
post #8 of 14 (permalink) Old Apr 12th, 09, 06:54 AM Thread Starter
Ulf
I connected the black and the blue wire, switched on the ignition and Eureka! Back up lamps working!
I'll order a new one, install it and splice the wires together. Problem solved!
I love it when it's this easy!
Omaniac is offline
post #9 of 14 (permalink) Old May 12th, 09, 06:11 AM Thread Starter
Ulf
Easy????
I managed to install this switch, but it's not the correct one. I could only attach it with one bolt, but that worked OK.
Problem is, the switch doesn't work the way it should. In PARK, the ignition works. It also works in various other positions as well.
The back up lamps don't work in R, but comes on when the shifter is in 2.
So now I don't know what to do. I can't find a switch that matches my set up.
Omaniac is offline
post #10 of 14 (permalink) Old May 12th, 09, 09:26 AM
Matt
What style shifter do you have in your car? Is it the horseshoe (upside down U) shifter? The switch you listed and got is specifilcally for that type of shifter. It should attach perfectly. Does your setup look like the pic below?
Matt
zlek131 is offline
post #11 of 14 (permalink) Old May 12th, 09, 11:29 AM Thread Starter
Ulf
No, It's not a horseshoe shifter. It's a "single" shifter. It is what you see in the top picture (top of picture is forward), and the switch attaches on the left side. I've had another look, and I think I can make a bracket to keep it in the right position.
I'm not able to adjust it far enough forward, that is why the back up lamps come on when the shifter is in 1 or 2.
The quality of the switch is not very good.
Omaniac is offline
post #12 of 14 (permalink) Old May 12th, 09, 12:56 PM
Matt
Which one of these resembles the switch you got?
Matt
zlek131 is offline
post #13 of 14 (permalink) Old May 12th, 09, 02:36 PM Thread Starter
Ulf
None of them. The one on the right is probably the one that would fit best, but I have a TH 350 tranny, and not a powerglide.
This is the one I've got:
Omaniac is offline
post #14 of 14 (permalink) Old May 12th, 09, 03:35 PM
Matt
Yes, that's right - I forgot you had the link to the switch you got. It does look like the one on the right would fit better. It looks like it would mount to the two little holes that your shiftier picture shows and the plastic U-notch would sit on top of the metal tab that's part of your shiftier. The switch you got really seems a bit "off" as all the other websites show one of the two I posted. Anyway you can return it and order another one? May as well fix it right and you can continue to drive your car as the switch doesn't make or break you.
Matt
zlek131 is offline
