Whats going on now? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 22nd, 09, 02:34 PM Thread Starter
Angry Whats going on now?
Here I go again. I just put a motor in my 81" Z28. About five days ago my headlights, stereo, and all interior lights went out at the same time. Now the car was running fine and i had no blown fuses. The signal lights and brake lights were still working. Two days ago I tried to leave the house the other day and I turned my alarm off stuck the keys in the ignition and didn't get any sound at all. I lifted the hood to see if I'd had a loose battery cable. I'd left the key turned on in the car after I tried to crank it again and I looked under the hood and there was smoke coming from behind the brake booster. I don't have any idea about electrical problems and i'm asking for the help of some other team camaro members. This is very frustrating
wjhoskins is offline
post #2 of 5 (permalink) Old Apr 22nd, 09, 04:56 PM
Skip
Skeeter55's Avatar
Re: Whats going on now?
Its sounds like the main igniton wire from starter/solenoid to the wiring block on the fire wall... Which connects to the interior fuse block..
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 5 (permalink) Old Apr 23rd, 09, 03:05 PM
if it was still smoking when the key was in the "on" position maybe it was the coil wire, or the main power wire coming into the harness. but if there was a short in that wire i figure it would've popped a fuse, whereas the starter wire wouldn't.
will, if you saw smoke something melted. pull the connectors off the firewall and start inspecting the harness. i think you'll be able to see where the problem is. and get a multimeter and start investigating, you'll find your dead wires.
Aaron67 is offline
post #4 of 5 (permalink) Old Apr 24th, 09, 04:30 PM Thread Starter
If that is the problem what do you think that I would have to replace?
post #5 of 5 (permalink) Old Apr 24th, 09, 06:30 PM
Will,
As mentioned,it could be as simple as a coil wire or as complex as a wiring harness that would need to be fixed/replaced. Aaron67 gave some excellent advice,get yourself a multimeter and also do an extensive visual inspection of the wiring.
David F.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
Tags
electrical problems, starting
