Wiper Motor Issues - Help Needed - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 24th, 09, 06:55 PM Thread Starter
Purchased a new wiper motor and washer pump for my 69. Wiper motor is acting very odd. It runs fine at low and high speeds but when I turn it to off it runs a complete revolution, pauses for a split second, and makes another revolution. Turn the ignition switch to off and back on and it continues the one revolution, pause a split second, and repeats. Does the same thing when I activate the washer pump, it seems to work fine. Could the switch be causing this? I know the switch acts as a ground but why the revolution pause then repeat? HELP!
Tim
1968 RSSS BB 396/325 AC TH-400 Black/Red (Sold)
1969 Nova SS 350 M-20 Red/Black (Original)
1967 Chevelle SS (Clone)(Project)
tim68rsss is offline
post #2 of 5 (permalink) Old Apr 24th, 09, 07:26 PM
Re: Wiper Motor Issues - Help Needed
Tim
Tim,
Just a thought........when you plugged the wiring connector(s) back on the wiper motor could you have "turned" or "flipped" the connector over? Here's a pic of how the connector should look..............
David F.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #3 of 5 (permalink) Old Apr 24th, 09, 07:31 PM
Another thing you can just barely see in David's pic is the ground strap that goes to the mounting screw. Make sure it's there, and it is clean enough to get good contact with the screw, sometimes they have a lot of paint on em. David's is nice clean shiny brass.
It sounds to me like the new motor is bad tho. The park switch is internal to the motor. It sounds like the switch is a lil "off" and the motor is coasting though it and getting powered up again. Do you have the wipers on and everything attached, that might load it enough to work.
post #4 of 5 (permalink) Old Apr 24th, 09, 07:52 PM Thread Starter
It is wired just like David's pic ..... thanks for the pic!
Yes it does have the grounding strap and I made sure everything was cleaned off, even where it mounts to the cowl. I have the transmission arms connected but not the wiper arms. It went through the park process one time maybe two but that is it. I was worried it may be an internal problem. Just can't figure why the dang thing won't stop running the one revolution pause and repeat
Thanks guys!
post #5 of 5 (permalink) Old Apr 24th, 09, 08:15 PM
Jeff
yellow69RS's Avatar
I think the washer pump might cause the pause and repeat. In my achieves here somewhere I have a GM manual on wiper motors only. I worked mostly on the round motors not the square. A worn "spring" in the wheel for the washer will cause the round motor to keep running. Pull the plastic cover off and make sure if the washer pump is shut off.
Jeff
yellow69RS is online now
