What type of alternator with HEI ignition? - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 28th, 09, 12:19 AM Thread Starter
Chris
Hi all, my alternator went out so I am researching what to replace it with. Here is what I am currently running:
396ci with HEI ignition
no radio
autometer oil and temp gauges
3 wire alternator (not OE)
Voltage regulator is not hooked up
I am considering going back to the factory wiring with an external voltage regulator and a Delco Remy 60 amp alternator from autozone.
Will this set up be sufficient enough to power the HEI ignition?
Thanks!
1969 X-22
Deevis69 is offline
post #2 of 6 (permalink) Old Apr 28th, 09, 07:01 AM
Re: What type of alternator with HEI ignition?
Yes, use a Wells p/n VR715 voltage regulator, its electronic and plug & play.
post #3 of 6 (permalink) Old Apr 28th, 09, 07:43 PM
Most likely the OEM alternator would be enough, but the VR714 regulator is a nice upgrade. The OEM alternator was a 3-wire alternator with an external regulator. Can you tell us if the small plug on the alternator has pins like this | | or like this _ _ ?
Personally I adopted the CS-130 and used the tech reference (links from the home page of this site) to do it.
dnult is offline
post #4 of 6 (permalink) Old Apr 30th, 09, 09:42 PM Thread Starter
Chris
The alternator that went bad has a "_ _" type plug (pic). The one I am replacing it with is a "| |" plug (pic).
I went ahead purchased a VR715 voltage regulator so I am going to stick to that plan since I have the parts.
Deevis69 is offline
post #5 of 6 (permalink) Old Apr 30th, 09, 11:01 PM
Good choice. Let us know how it works out.
post #6 of 6 (permalink) Old Apr 30th, 09, 11:23 PM Thread Starter
Chris
Thanks Everett - I'll post again once I get it going
Deevis69 is offline
Tags
alternator, generator
