Brake lights keep blowing fuse - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 30th, 09, 10:12 AM Thread Starter
68 camaro just started blowing brake light fuses. Tail lights work fine, turn signals work fine. Any ideas? "Painless" wiring harness. No issues until now...of course a cruise is coming up this weekend, so I would REALLY like to figure this out sooner rather than later!
Appreciate any insight... Brian
Globemaster68 is offline
post #2 of 3 (permalink) Old Apr 30th, 09, 01:49 PM
Jeff
yellow69RS's Avatar
Re: Brake lights keep blowing fuse
The wire from the brake light switch goes to the turn signal switch. Have you done any work under the dash near there that might have pinched it. If everything else works without blowing fuses that's the first thing I'd look at.
Jeff
yellow69RS is offline
post #3 of 3 (permalink) Old May 3rd, 09, 08:47 PM Thread Starter
I have a Torque Converter locker that hooks through the brake switch. Something is causing it to short to ground. I disconnected it from the brake switch and stopped blowing fuses. Thanks for the try though. Now I just need to figure out why the converter lock is grounding out!
Thanks again,
