Turn signal on at all times? - Team Camaro Tech
post #1 of 8 (permalink) Old May 3rd, 09, 12:34 PM Thread Starter
kirk
I replace turn signal and now left front turn signal is always on? not rear? even when turn signal is in off position or right hand turn the left is always on.
Kirk
67' Camaro Convertible, 454, 540 HP, 400 turbo, 2800 stall, 12 bolt 411 posi
orange67vert is offline
post #2 of 8 (permalink) Old May 5th, 09, 06:27 AM
Roger
Re: Turn signal on at all times?
Sounds like it could be a problem with your 4 way flashers....I have a similar problem where if I just touch the 4 way button, the left signal comes on....I haven't got it fixed yet
Roger 67 RS/SS350
Roger344 is offline
post #3 of 8 (permalink) Old May 5th, 09, 07:26 AM Thread Starter
kirk
Roger344 when you say 4 way button? do you mean the flasher? When this happens if I pull up on flasher and turn signal it stops. i know there's a short some where just haven't figured it out yet. Thanks for your reply.
Kirk
post #4 of 8 (permalink) Old May 9th, 09, 11:33 AM
Roger
Yes, I was talking about the 4 way flasher button....sounds like we have the same problem....and I recently replaced my turn signal switch in the steering column....for now I just removed the flasher unit for the 4 ways because it would come on while just sitting in the garage.
Roger 67 RS/SS350
Roger344 is offline
post #5 of 8 (permalink) Old May 9th, 09, 12:26 PM
Sometimes the contacts get so gunked up they actually arc across and make contact when they are not supposed to. Try cleaning them up with wd-40 or brake cleaner and then follow it up with compressed air. The keyboard cleaner in a spray can from an office supply store works best since you can fit the straw nozzle on the can and get way in there.
cruzinquick is offline
post #6 of 8 (permalink) Old May 10th, 09, 06:06 PM
Roger
Well, mine is a brand new signal switch and Kirk said his was just replaced....perhaps there was too much dielectric grease on them from the factory...it's worth a try to clean up everything.Thanks for the idea!
Roger 67 RS/SS350
Roger344 is offline
post #7 of 8 (permalink) Old Jun 8th, 09, 01:48 AM
H
How do you change your turn signal switch?!
250motorsportz is offline
post #8 of 8 (permalink) Old Jun 15th, 09, 01:29 PM
Roger
It wasn't all that hard but I really can't explain it easily.....I just started tearing the steering column apart until I could take out the switch/wiring harness, then replaced it. I'm not a mechanic, so I think it was pretty self explanatory.
Roger 67 RS/SS350
Roger344 is offline
